Death Wobble experience
Old Jul 10, 2011 | 04:40 PM
  #61
Marauder92V's Avatar
Marauder92V
Another one for 406. Don't know if it is a 2011 though... Ford Truck World - Track Bar Bushing - Wont Last! (Super Duty)
Old Jul 10, 2011 | 04:43 PM
  #62
kper05's Avatar
kper05
Originally Posted by lexustbs
No, I ruled out the ravine because I had one episode of death wobble a few weeks before the "incident", it was going over a set of rough railroad tracks and the wobble started and did not stop till about 5mph.
Come on, a ravine?
lol - you said ravine in your title when you showed us pictures so we would read it.
Old Jul 10, 2011 | 04:49 PM
  #63
lexustbs's Avatar
lexustbs
I had to spice up the title so you would click on it.
Ok, I might do this plan. Replace the shocks and steering damper with Bilstein, then install the WC trackbar with the metal ends. Then go get an alignment with increased caster.
Is this trackbar the same as the WC? http://www.iconvehicledynamics.com/s...r-with-Bearing
Anybody agree with it?
Also, who all has experienced a death wobble with their 2011? Or who experiences a steering wheel that shakes a bit when hitting bumps.
Old Jul 10, 2011 | 05:28 PM
  #64
Tom's Avatar
Tom
Nope. The second you start changing out parts Ford is no longer responsible for correcting the issue. What if you spend some money on parts and it doesn't fix the problem? At that point warranty won't help you any.
Seriously, this really needs to get to a dealer for proper diagnosis. The best part about this is that since you're under warranty IT'S FREE!
Old Jul 10, 2011 | 05:32 PM
  #65
Tom's Avatar
Tom
Check this out, Tyler. Posted in another thread here in the 6.7L forum:
Originally Posted by Rickx
I had the dreaded "Death Wobble". I found a place I could reproduce the "wobble" at will. It was a manhole that was about 4 inches below road grade and I would hit with my left tire. This is where I took the Service Manager for rides.
I put my truck in the dealer's shop the first time and they replaced the front shocks and said a nut had "loosened". I'm assuming the nut was on the ball joint for the track bar. They said the front shocks were dead.
Several months later I took it back in with complaints of the front end bouncing too much. They replaced the front shocks again.
On the drive home I still wasn't happy with it. I called the dealer and got the number for - THIS IS IMPORTANT, SO PAY ATTENTION - ask for the number of FORD CUSTOMER ASSITANCE and file a formal complaint. I called them and they opened a ticket on my truck. I took it to the dealer and left it for a week.
The Ford engineers came onsite and were in charge of all repairs.
They replaced the front shocks with upgraded factory certified Rancho 5000s. They also replaced the track bar and ball joint, along with the steering damper.
This DID fix my problems and I am happy with my truck again.
They also tested and replaced my rear shocks, they said they were weak. This eliminated the bounce I was getting on concrete highways and was not part of my complaint, but I sure am glad they did it. I was ready to pull the trigger on a Firestone R4Tech airbag system.
Before I took it in, I talked to Steve at WC Motorsports about their track bar solution - $825.00 - parts only.
But the item of note is he said you can't run BFG All Terrain KOs on these trucks - which I am. I have standard size with 18" rims. I noticed if I ran 65lbs in the fronts it would bounce like crazy and the Death Wobble was easy to reproduce, but if I put 70-75lbs in them, no death wobble. I did report this to the Ford and their response was, you should be able to run any tire of the right size on these trucks without issue.
Now I am running my BFGs with 65lbs and have no issues.
He took it to a dealer and had a proper diagnosis done. And it fixed the problem better than what can be claimed by another aftermarket solution.
Old Jul 10, 2011 | 05:39 PM
  #66
720Deere's Avatar
720Deere
The track bar video pretty clearly shows the issue. That amount of movement on the bar along with sub-par shocks is never a good combination.
I don't know the exact number, but I know that you need a torque multiplier to torque the track bar. It is not a job for the faint of heart!
Old Jul 10, 2011 | 06:46 PM
  #67
lexustbs's Avatar
lexustbs
I understand where your coming from, but if the track bar is the issue then I want a long term fix. Plus the whole week without the truck just won't do.
What would cause the track bar to go bad anyways?
Old Jul 10, 2011 | 07:05 PM
  #68
Tom's Avatar
Tom
I'm sure it's the bushings at the end of the bar instead of the bar itself, maybe there's no good way to replace them?
I'd say it would be a long-term fix considering how rare these problems are. Joel(ruschejj) had his '08, which used the same components, for over 150,000 hard towing miles. He never posted about any trouble with the death wobble.
Looks like yours is just defective.
Old Jul 10, 2011 | 07:33 PM
  #69
lexustbs's Avatar
lexustbs
Cancel post. I took a picture at that angle and it looks the same....
Old Jul 10, 2011 | 08:03 PM
  #70
AlexWV's Avatar
AlexWV
Originally Posted by EpicCowlick
Sure would like to understand the basis for that post. We're trying to reason out some solutions and that statement in itself is not helpful. Do you know the background of that opinion?
One thing that is clear, there is likely not one single solution to the wobble. There's probably a root cause and then failure of other parts of the system that allow it to happen. Poor alignment, worn shocks, bad tires will all need to be corrected. If Lex sees some improvement with the stabilizer and alignment change but still feels like something is off, we'll keep working on it.
You quoted that like I said it. To be clear, it was a comment from somebody, not me, on a TDS death wobble thread for which I gave the title.
That being said, I have no idea the background of that opinion but since you post on that forum (I assume it is you, same handle) you could ask him.
He could be talking out his clacker for all I know, or maybe he knows what he is talking about.
Do you reckon he's wrong and you're right? If you don't know for sure the answer to that question, you probably shouldn't be advising people to add caster. Right?
I agree with Crazy mustang guy, "we" shouldn't be fixing this, Ford should.
Old Jul 10, 2011 | 08:13 PM
  #71
720Deere's Avatar
720Deere
I think there was a misunderstanding where Epic thought that caster was being ignored. I think the confusing came from a statement about adding caster. If I am thinking correctly what Epic has been suggesting is actually taking away caster or going negative. This adjustment will definitely help with bump steer which is one contributing factor in the death wobble.
Lexus your track bar issue can be likened to a starter failing at 10,000 miles. Components can and do prematurely fail for various reasons. Usually track bar issues on these trucks are typically caused by lifts of 2 or more inches, wider wheels or different offset on the wheels and large aggressive tires. I don't recall you having any of this done to your truck so I'm going to say you just unluckily got a "10,000 mile starter".
  #72
lexustbs's Avatar
lexustbs
Adding caster is something a lot of people suggest. Even the WC bar guy suggest adding caster more than factory spec. So I'd say this is a good idea.
Have you ever been to the dealer for a squeak or rattle that you hear, but the tech can't or won't? Kinda frustrating huh. I'd rether fix this myself than have the dealer take two weeks and replace subpar parts with more crappy subpar parts.
Old Jul 10, 2011 | 08:16 PM
  #73
lexustbs's Avatar
lexustbs
I agree 720. Do you think there is excessive play in the trackbar. I know you hinted at that in a previous post, but can you tell me more?
Old Jul 10, 2011 | 08:20 PM
  #74
720Deere's Avatar
720Deere
Okay I'm a dunce! I just googled it to make sure I'm not talking out my nether regions, but of course I was. The direction that you need to move is actually positive or rotating the top of the differential assembly toward the rear of the vehicle. Rotating it forwards would cause heavier steering and bump steer. I knew the direction of movement, but I was using the wrong terminology.
Old Jul 10, 2011 | 08:21 PM
  #75
cford716's Avatar
cford716
I agree completely. Have Ford re-torque all front end components and check to see if the tracbar ends have started to get ovaled out. And a wheel balance and alignment to round it out wouldn't hurt. Although an out of balance tire will not cause a death wobble but a speed related wobble or shimmy. Several guys on the Jeep forum commented that they just started to replace parts and that they regretted it. Problem was that it didn't fix it and now it was starting to damage the new parts. Have to find what is causing it. Something is loose or damaged on the front end. Just my 2 cents, not a mechanic, just deferring to the Jeep guys who seem to have way more experience with this that any other vehicle.
This is the first I have ever heard of on anything other than Jeeps. Until now I thought that they were the only ones that had this issue.
Good luck, and keep us posted.
