Cranks but no start Code P0603 Internal Control Module KAM Error
Old Jul 9, 2011 | 08:43 AM
  #31
mueckster's Avatar
mueckster
Originally Posted by hotroddsl
I wouldn't expect it to as it only uses a 5 volt modulated signal I hope you did not burn it up!
IPR uses 12 volts power supply. You can see the circuits that share a common power source in the following schematic.
IPR wiring.pdf
Old Jul 9, 2011 | 08:50 AM
  #32
hotroddsl's Avatar
hotroddsl
Sorry my bad, you learn something everyday, I've always been assuming it ran can bus volts!
Old Jul 9, 2011 | 09:51 AM
  #33
Action4478's Avatar
Action4478
Originally Posted by garsm
I put 12v directy to the IPR and it doesnt click or anything. It may be stuck open really bad?
Use a test light (very carefully ) & see if there is voltage at the IPR , key on ..
lakewood
Apr 5, 2015 01:27 PM
Stroked 89 CA
Jun 22, 2014 11:15 PM
Dutch Semi
43
Apr 10, 2012 05:45 AM
jcahicks
Mar 23, 2010 10:46 PM
powerstrokin95
Dec 7, 2004 07:58 PM
