Cranks but no start Code P0603 Internal Control Module KAM Error
Old Jul 7, 2011 | 07:45 PM
ToMang07's Avatar
ToMang07
P0603 is an PCM error that it's memory was wiped... like I said in your other thread it's from either the batteries being disconnected, or a flip-chip. (Or removing the PCM.)
I get the 603 code each time I use my PHP chip.... nothing to worry about.
Old Jul 7, 2011 | 07:46 PM
garsm's Avatar
garsm
like?....ive rulled out a lot
Old Jul 7, 2011 | 07:49 PM
garsm's Avatar
garsm
well me truck wont start and yes i took the pcm out so I guess that can be explained but how about the other numbers I posted?
Old Jul 7, 2011 | 07:53 PM
Action4478's Avatar
Action4478
You can block the HP lines one side at a time , it will require some fittings to cap the line . If you have a leak in the replaced injector , block off that side . If that is what is wrong ,the ICP will increase & the truck may well start .
If you wish , you can use a gauge in the lines to verify ICP . This way , you can unhook both lines & dead head the HP Pump to test the IPR with the gauge ....
Old Jul 7, 2011 | 07:56 PM
Action4478's Avatar
Action4478
Did you notice if the ICP voltage increased while cranking?..
IIRC , it needs to be .8 ...
Old Jul 7, 2011 | 07:57 PM
garsm's Avatar
garsm
no, it stayed at .2
Old Jul 7, 2011 | 08:02 PM
Action4478's Avatar
Action4478
Look closely at the connector to the ICP sensor . Have you double checked the wiring to the IPR & everything in that area ?..DO you have a DVOM ?...
Old Jul 7, 2011 | 08:04 PM
garsm's Avatar
garsm
ok will do tomorow and yes I have a basic volt meter
Old Jul 7, 2011 | 08:08 PM
Action4478's Avatar
Action4478
Look for 5V Ref signal ,
, If you hold the ICP connector looking into it with the latch on top, the left pin is Vref, center is ICP signal, and right is Signal return. The corresponding wire colors(IIRC) should be brown/white, dark blue/light green, and grey/red.
At key on, you should get a .25v to .4v signal. Operational range for the sensor is .65v to 3.25v. Some approximate pressures compared to voltage signal would be:
500psi = about .85-.87v
1000psi = about 1.4v
1800psi = about 2.3v
2400psi = about 3v
3000psi = about 3.8v
Old Jul 7, 2011 | 08:09 PM
Action4478's Avatar
Action4478
Originally Posted by garsm
no, it stayed at .2
Was that while cranking ?...
Old Jul 7, 2011 | 08:10 PM
garsm's Avatar
garsm
yes while cranking
Old Jul 7, 2011 | 08:13 PM
Action4478's Avatar
Action4478
Thats all I have for now . Let us know what you find out . Chris & others may have more ideas too...
Old Jul 7, 2011 | 09:26 PM
  #28
hotroddsl's Avatar
hotroddsl
Remember his crankcase was 2 quarts overfull after initial event! I think he popped some o- rings and can't make inj. Pressure?
Old Jul 8, 2011 | 10:49 PM
  #29
garsm's Avatar
garsm
I pulled the injector I changed an the O rings looked fine to me...should i check all others. Also, I put 12v directy to the IPR and it doesnt click or anything. It may be stuck open really bad?
Old Jul 8, 2011 | 11:49 PM
  #30
hotroddsl's Avatar
hotroddsl
I wouldn't expect it to as it only uses a 5 volt modulated signal I hope you did not burn it up!
