Leveling 2wd...im confused
Old Jul 7, 2011 | 11:41 AM
str8sixman's Avatar
str8sixman
hey guys, 93 f150 4.9 2wd bare bones truck
wanting to level out front end, so started doing some research. i went to the sticky thread about the springs, and found my door code to be "C D" but not sure what that means. i looked on broncogravceyard.com and found superlift coil spring for 135. they are 17'' unloaded with a spring rate of 400 lb/in....i can get a set of springs from napa that are 16.94" unloaded with a spring rate of 366 lb/in.for $88....would that give me about the same amount? i also noticed that the napa dimensions are the same as the tallest ones listed in the sticky thread post
im not really sure where to go from here, i dont want to lift so much that i cant align it, but still want the front end to look level
has anyone tried the coil spring spacers ive seen daystar makes them, but wonder how much stiffer the ride would be?
any help/advice is appreciated, id hate to buy springs that i cant return and wont fit on my truck...thanks!!
Old Jul 7, 2011 | 12:25 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Dont go cheap on suspension products
Old Jul 8, 2011 | 12:36 AM
Slowroll90's Avatar
Slowroll90
Do you know the stock spring rate?
Have you measured the unloaded height of the stock springs?
I think mine are sagging a tad
The spacers shouldn't make the ride any stiffer
Like lift block, they just change where the spring sits
I did the lowering shackles on my 2wd and it wasn't quite as dramatic as I hoped
I've actually considered the daystar spacers
Old Jul 8, 2011 | 12:46 AM
TexasGuy001's Avatar
TexasGuy001
Are the Napa springs made by Moog, and are they F250 springs?
Old Jul 8, 2011 | 12:48 AM
TexasGuy001
Use springs not spacers. Alot of guys use the Moog 250 replacement its part number is 88 something. The Superlift leveling springs are fine too. I have had them before and so does my friend.
Old Jul 8, 2011 | 10:06 AM
Will Chiello's Avatar
Will Chiello
I bought my truck with super lift springs in my 92 F150 4x4 and they are stiff. Also it made my tires kink in on the bottom, so now the cambers have to be ajusted. IMO i would just live with the sag in the front, but its your truck.
Old Jul 8, 2011 | 11:26 AM
str8sixman's Avatar
str8sixman
F150 installed load rate free length
CC818 12.13" 1258 337 15.75"
CC820 12.13" 1428 366 16.19"
CC822 13.00" 1430 366 16.38"
CC824 13.00" 1442 366 16.94"
F250
CC844 12.75" 1557 630 15.40"
CC844S 13.00" 1759 629 15.79"
F350
now the biggest spring run on an f150 is a cc824, which is also on the f250s, and that is the one that matches pretty close to the superlift springs...the springs on my truck now are 12'' loaded so they are either 818 or 820...if they are 820s then the 824 wont net a full inch because the spring rate is the same. but if they are 818s then the rate is 337 vs 366...will that be enough to hold the spring up or is the 844 my best bet because at 630lb/in, its doubtful that my fairly light front end will lower them much more than the 15.40 height?
im really sorry to ask weird stuff like this, im not sure i make any sense to you guys
btw the truck measures 3'' higher in the rear.....if my thinking is correct the 844 will be perfect, but i just want some reassurance
Old Nov 5, 2013 | 09:46 AM
bout-time's Avatar
bout-time
F250
F350
I know this is an old thread, but what springs did you end up using in the front? Ire you satisfied with the look and the ride quality? Can you post pics?
robert_l_ross
Sep 1, 2023 03:17 PM
mouks
Feb 9, 2017 06:55 AM
resonateur
Oct 26, 2015 10:01 PM
tmcconnell22
Dec 1, 2014 05:49 PM
harrington
Jan 5, 2013 04:05 PM
