5.0 cooler swap
Old Jul 7, 2011 | 11:01 AM
luvemhot's Avatar
luvemhot
5.0 cooler swap
I am getting ready to swap out my cooler with a 6.0 cooler.
Both the inlet and the outlet on the new cooler is a 1/2 barb fitting. Both the hard lines at the engine seem to be the same size, making it so I can not tell which lines to hook together. Does it matter to keep the right flow of the fluid. Does it matter what line I hook up to the hard lines by the engine? Is the in and outlet the same for both coolers? If they are the same then i can figure it out easy. If not how can I tell what what is the inlet on the cooler and what hard line would be the inlet.
Thanks Keith
Old Jul 7, 2011 | 11:53 AM
snakedoc's Avatar
snakedoc
see if this will help.
https://www.ford-trucks.com/forums/6...-write-up.html
Old Jul 7, 2011 | 01:25 PM
Rushmore X's Avatar
Rushmore X
Definitely worth doing!
Old Jul 7, 2011 | 02:35 PM
luvemhot's Avatar
luvemhot
Matt Thanks
I had looked at that write up it help a little. Now I need to make sure which is the return line on the new cooler. My guess is that it is on the passenger side when it is installed on the rig.
Trent you live where my sister lives great place.
Old Jul 7, 2011 | 03:03 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Direction of flow does not matter in the cooler. Not sure if your 99.5 has the tranny fluid going thru the radiator like my 02 does, but I plumbed the cooler in after that, then to the return line. If you do not already have them, you'll need two of the 1/2 to 3/8 hose barb adapters cuz the 6.0 hoses are 1/2 and your 7.3 hoses are 3/8. A filter like a Magnefine plumbed before the cooler is cheap insurance.
Old Jul 7, 2011 | 04:10 PM
luvemhot's Avatar
luvemhot
Dave
Thanks the filter is one thing I forgot to get. One more trip to the parts store
Old Jul 7, 2011 | 07:19 PM
woodnthings's Avatar
woodnthings
Here is something I wrote up for cooler install.
https://4656923915310766587-a-180274...edirects=0&d=1
Old Jul 7, 2011 | 07:20 PM
Rushmore X's Avatar
Rushmore X
Originally Posted by aawlberninf350
Direction of flow does not matter in the cooler. ...
That's what I heard too... Highest temp I've gotten was 172 with the AC on full going up a 10% grade puling a 18.5 foot Sea Ray... most of the time runs in the 130's
