Part # request - vacuum motor
Old Jul 7, 2011 | 11:00 AM
Shark Racer's Avatar
Shark Racer
This is for my 83 460 4x4/T19 F-250HD, CA emissions.
Need a vacuum motor part # to cross ref. Not sure the difference between the various "stripes", and mine's been painted over at some point. (I may or may not be willing to admit guilt on that front)
At any rate, this "motor" is the diaphragm canister that controls the flapper valve in the intake duct (to let exclusively warm exhaust air in).
Thanks in advance!
Also, does anyone happen to know the difference between the various stripes?
Old Jul 7, 2011 | 11:41 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
If it is like the transmission vacuum modulators, it probably denotes the vacuum needed to operate it. Numberdummy may be able to give you a PN, but he may need the emission calibration number either from the label on the panel in front og the radiator or the left valve cover.
Old Jul 7, 2011 | 12:26 PM
Shark Racer
Thanks, if that's the case I can nab those when I get home tonight.
I wouldn't be surprised if it were. Honestly, if I weren't stuck in the state of CA, I'd probably just get rid of the series of vacuum hoses used to control it.
Old Jul 7, 2011 | 12:30 PM
Franklin2's Avatar
Franklin2
That thing is your best friend if it gets cold where you live. The warm air when it gets below around 40 degrees really makes a difference in how it runs.
I am surprised it's bad. Of all the junk aircleaners I have around here, I have never seen a bad one before.
Old Jul 7, 2011 | 12:41 PM
Shark Racer
Hooked my vacuum pump up to it, doesn't hold a vacuum at all, and the flapper doesn't respond. I suspected as much when I repainted the air cleaner assembly a few months back, as manually actuating the flapper didn't give the usual sucking noise response I've grown to expect from a vacuum motor.
Old Jul 7, 2011 | 12:43 PM
ctubutis's Avatar
ctubutis
Luckily enough for Shark Racer, there weren't too many calibration codes used on 1983 F250/350 with the 460 & California emissions.
There was ONE:
Calibration Code 3-98S-RO
Applies to:
8 Cyl. 460 C.I.D. (7.5L)
1983 E250/350 with Automatic Transmissions in California
1983 F250/350 with any transmission in California
From there, I found the damn vacuum motor....
D7AZ-9D612-C Motorcraft # CX-149 Motor Assy. (carburetor air cleaner vacuum)
Color code: blue
Vehicle line: F-Series
If you're interested, Green Sales Co. has 2 of them, and Rock Auto has 'em for about $30 (use the Motorcraft number).
Old Jul 7, 2011 | 12:46 PM
Shark Racer
Originally Posted by ctubutis
Luckily enough for Shark Racer...
Chris - if you're ever near the south bay area in CA, or I happen to be in your neck of the woods, I'm taking you out for pizza & beer.
Thanks so much!
Old Jul 7, 2011 | 12:57 PM
ctubutis's Avatar
ctubutis
I'll take ya up on it if I'm ever in SanFran again.
whiteboyslo
17
Aug 4, 2020 05:10 PM
MisterMichigan
Jan 4, 2017 06:00 PM
Jlames
Aug 18, 2015 11:42 PM
jayro88
Jul 19, 2014 08:37 PM
bluesmanmike5
Jun 15, 2011 03:21 PM
