Light in the cabin
Old Mar 28, 2003 | 11:34 PM
carpe_diem's Avatar
carpe_diem
Light in the cabin
1989 Ford F250HD, Lariat package
I am talking about the light bulb in the ceiling that turns on when the door is opened or it is turned on manually via the headlights switch.
It is not bright enough due to its plastic cover. The cover is not clear, it doesn't let enough light through. Not enough to look at a map. I want to replace this cover with something clear, any suggestions?
Old Mar 29, 2003 | 12:18 AM
Fusion's Avatar
Fusion
Light in the cabin
My 81 F250 has the cab light with the map lights on either side, you can turn the map lights on via a black switch mounted by the lights. If you can find this cab light set in the wrecking yard it will be nice and bright in your cab.
You could also make your own new cover using pvc and plexiglass, just cover the pvc spacer in a material that is similiar in color to your <a href="http://www.motorhaven.com/">headliner</a>.
Old Mar 29, 2003 | 12:45 AM
Mil1ion's Avatar
Mil1ion
Light in the cabin
That's weird that Lariat came with a dome light instead of the light package which included the map lights.
If you can't find one out there,.. contact me privately.
Old Mar 29, 2003 | 10:31 AM
carpe_diem's Avatar
carpe_diem
Light in the cabin
I do have 2 other map lights right in the same place and they are equally dim.
Old Mar 29, 2003 | 12:09 PM
Mil1ion's Avatar
Mil1ion
Light in the cabin
Check the bullbs to make sure they are the suggested model.
Bulbs do weaken over time.
Perhaps a different Number bulb will make more light.
Old Mar 30, 2003 | 01:44 AM
carpe_diem's Avatar
carpe_diem
Light in the cabin
Actually, the bulb is bright enough without the cover, the way I have it now. It is very bright. It is the plastic thing that goes over it which obstructs 80% of the light.
Old Mar 30, 2003 | 12:15 PM
steve83's Avatar
steve83
Light in the cabin
Look at the dome lights I have here in pic #43. You can use the newer plastic dome lamps instead of the older chrome ones - they mount to the same terminals and fit fine. Their lenses are clearer and don't age like that white one.
Brown Falcon
28
Jul 26, 2020 09:55 PM
sere0501
Jan 3, 2015 12:06 AM
TickTock
Nov 18, 2011 05:30 PM
alvald83
Oct 12, 2010 11:40 AM
B25Boxer
Aftermarket Products
Oct 14, 2001 02:20 AM
