Emergency Transmission Problem
__________________________________________________ _________
1999 E320 (mine but daughter has it)
1994 F150 #1 (hurt)
1994 F150 #2 (parts)
1989 560 SL (wife's DD)
1986 560 SL (deceased)
1988 300 TE (departed)
1994 945T (daughter's but I have it)
1988 244DL (it lives!)
1986 242Ti (fallow)
1968 GT500KR (under restoration)
I guess I just assumed (bad idea, I know) that "reading" also reffered to "replying".
As for letting it drop, it's a done deal as far as I'm concerned, and won't be brought back up (by me) again. Just like it wasn't brought up by me this time. He(?) made ammends, and I accepted. Done deal in my book.
(again, assuming it's a "he" based on the info given)
Bad days happen. I understand that. I assumed the OP was a younger person due to the reaction given, but I didn't refer to them as a "kid" or make any other age-related comments. Might have, had I not been due elsewhere when I first responded to the reply. I deal with a lot of younger folks where I work part-time. I treat them the way they treat me, like anyone else I interact with.
I don't coffee anymore. I have it infused VIA IV.......
On the other hand, I'll be happy to give ya all the moral support ya need.
1983 was the last year gas-engined trucks used the mechanical clutch linkages (which didn't give the firewall problem); 1982 the last year with diesel-engined.
I guess diesels had the change first due more pedal effort with a heavier pressure plate
I assume diesels had the change earlier due more pedal effort with a heavier pressure plate.
Here in the USA, there was no diesel option until 1983 or 84. As far as I am aware, all of the diesel powered trucks here in the states had a hydraulic clutch.
This brings me to a question, what diesel options did you guys have in the early 80's? Ours was only the Navistar/IH 6.9L V8, and then only in F250HD/F350 trucks.
We didn't get 300's, 400's or 460's though. The Australian built trucks were fitted with 250 six cyl. motors, or 302 & 351C V8's.
Re clutches - I might have assumed the hydraulic clutches on diesels, were preceded by mechanical linkages, like gas motors.
I just remember that from those dates onward, the respective clutches were hydraulic.
Bummer you guys never got the 300, but I guess having the 351C makes up for that..... I knew the 351C went "down under" after 74.
I've though about trying to immigrate to that part of the world. The 351C used to be part of the reason. These days, it's that turbo I6 in the falcon/falcon ute (I SOOOOOOO want a falcon ute XR6 turbo) and the diesel ranger that have me dreaming of the aus/nz lifestyle.......
Yep - the XR6 & XR8 utes are beasts
I should stop messing up this guy's thread with trivia
Me likey the ute's, Too bad they don't sell them over here... I'd rather have the XR6 though, just cause it ain't a V8.
This thread got off to a bad start, but got back on track. Now here we are getting it back off track. We're so bad......
No disrespect intended to the OP. Sorry mate. I'll quit hijacking it now.
I had hoped I could utilize the cross member from the '94 but it isn't a direct swap. I would have to drill holes in the frame about 1 1/2" to the rear to accomodate it and I am not sure it would be OK as it seems the mounting holes don't quite line up side-to-side. The crossmember from the '83 lines up OK but will require drilling holes about 4-5" to the rear. Can't use the mount from the '94 w/ the crossmember from the '83 & vice-versa as the height is different as well as the bolt separation. Any suggestions as to which would be the best way to go? I'm leaning toward the '83 crossmember & mount right now.
Haven't mounted the master cyl for the clutch yet. There is a large plate upon which it needs to be mounted, the rib DB mentions is obvious. With that plate, is it necessary to add the plate from the '94? My Mcyl only has 2 bolts, not four as DB mentions, unless I am misunderstanding.
1994 F150 #1 (hurt)
1986 242Ti (fallow)
1941 Luxury Liner (son's project)
drilling the holes is hard on the arms, bit use small to large bits, start wih small bit, go to 1/2 the size you need, then the size you need. It's time consuming, but you, or the drill bit don't wear out that way.
hardest holes to drill will be the top ones
here is another thread going on that might be of some help with the clutch
Hydraulic clutch conversion
looks like the link failed, look in 80-86 forum for that tittle, unless Chris fixes it for me.......
good luck, ask if you need to, we're here to help
Thanks DB for the hole drilling process. SOP for me for many years. Just have to make sure the holes do not get too close to the edge of the frame. I think it will be OK.
Got the Mcyl. in, a RotoZip is a wonderful tool.
I'm hoping the actuating lever attached to the clutch pedal shaft will provide sufficient throw with the geometry as is (it was set up to push the shaft through the floor vs. the firewall). So there is somewhat less throw than there could be were the lever rotated 45-60 degrees. Tried using the lever from the '94 but it isn't compatible. We will see if it works shortly. Otherwise, we will see if the pedal assy. from the '94 will transfer over.
1994 F150 #1 (hurt)
1986 242Ti (fallow)
I might try to fab up a lever arm with a different angle first. Not hard, just time consuming.
1994 F150 #1 (hurt)
1986 242Ti (fallow)
