I did mine a few weeks ago. If you can put enough suport on the engine (blankets) to rest your body on the engien and you may get them. Removing the up-pipes and y-pipe will hlep.
do you have a little kid slave to reach back there?
Note, they are even harder to put on than taking them off.
awesome thanks for the advice ill try both. i could get a 8mm wrench on there but i just couldnt get it to break loose so i was wondering if there was an easier way
You might want to use a 1/4" drive ratchet with either an 8mm or 5/16" six point socket instead, so you don't risk rounding the head of the bolt while trying to crack it loose.
