Screeching Turbo??
Old Jul 8, 2011 | 08:06 AM
2006lariat's Avatar
2006lariat
Originally Posted by olbattlebuggy
6.0 doesn't have a blow off valve???
Nope That is why they fart through the intake when the butterfly is slammed shut! All the excess boost comes back, out the intake.
Afhoofhooofoooohhhhhhhsihhh
Old Jul 8, 2011 | 08:59 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I knew that...... but give the guy a break....only 16 posts here on FTE....he's still learning! And he's in a great place to learn!
battlebuggy, go up to the top of the 6.0 forum and get into those "READ FIRST" posts! They will keep you going for DAYS!
Old Jul 13, 2011 | 11:08 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
No one was right..... loose nuts on engine side of cat!!! Actually they were the WRONG nuts.....prob from the headgasket repair a year ago......but I can't prove that.....but it wasn't the first time I found shoddy work from that repair. Many body bolts missing/loose from lifting the cab..... they yanked the plastic push screws from the rubber air dam under the grill.....Don't think I'll be using THAT dealer again.
Old Jul 13, 2011 | 11:57 AM
GeneLaw1's Avatar
GeneLaw1
I think I have been having this same problem, at times I hear a noise that sounds like a siren when i decelerate...is that about the same thing??
Old Jul 13, 2011 | 12:22 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Not what I heard.... mine was really a SCREECHING noise.....like a metal to metal scraping sound. But hey, it COULD be a beginning of what I had... easy enough to check...crawl under and try to wiggle the CAT pipe BEFORE it goes into the cat. Oh...be dang sure the pipe is COLD!
Old Jul 13, 2011 | 01:37 PM
JESTERxHEAD's Avatar
JESTERxHEAD
**cough** **cough** there isnt a butterfly on 6.0L's either...
(not counting the egr throttle on EARLY '03's)
hehehehehehehe just givin' ya a hard time!!!!
tr0y
35
Dec 13, 2015 08:38 PM
bizzelj
Sep 4, 2015 10:43 PM
stormblue
15
Apr 5, 2015 02:49 PM
Goldenvoice
Apr 2, 2015 11:48 AM
TourqueRise
19
Aug 27, 2009 11:10 PM
