What is this?
Old Jul 6, 2011 | 01:02 PM
devino246's Avatar
devino246
What is this?
Can anyone tell me what the nipple in the middle of this pic goes to? It was capped off and I figure its probably on the truck for a reason. Thanks in advance.
Old Jul 6, 2011 | 01:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This was a 2, 3 or 4 ported vacuum delay valve. Someone broke the top half off that contains the ports, then capped off the remains.
Which ported valve it is, I dunno...because you failed to list the engine size, CA vehicle or not.
Could be an 8A564 coolant temp valve, 9D473 EGR vacuum control valve, or a 12A091 dizzy vacuum control valve. But, these are only the Ford basic part numbers.
There are myriad different types of each, as it all depends on the application.
Sold new is CA vehicle: The DSO code on the Warranty Plate will be either 71 or 72.
Old Jul 6, 2011 | 02:21 PM
devino246's Avatar
devino246
Sorry
1979 F150, 351m
has a catalytic converter
DSO code is 17-Washington
I dont think its a VCV, unless this engine should have 3 of them. The EGR VCV is just out of frame and working. Theres another 4 port thats in front of the distributor, also working.
I just got the EGR hooked up and retimed the engine which has gotten it running better than ever. Performance is good, just curious what this thing is.
Old Jul 6, 2011 | 02:49 PM
devino246's Avatar
devino246
Speaking of vacuum parts, the vacuum resistor which limits the amount of vacuum that reaches the distributor is missing. Autozone lists a "spark delay valve". Is that the same as the v rest listed on my vacuum diagram?
Old Jul 6, 2011 | 06:43 PM
ranger429's Avatar
ranger429
That is not a picture of a broken ported vacuum switch. It is a simple vacuum fitting screwed into the intake.
Old Jul 6, 2011 | 07:42 PM
fmc400's Avatar
fmc400
MSEE
Yep, just a vacuum fitting. It's a handy spot to plug in a vacuum gauge. Just cap it off.
Old Jul 6, 2011 | 07:43 PM
NumberDummy
A 'simple' vacuum fitting screwed into the intake manifold...for what?
What genuine Ford vacuum fitting resembles what you posted? Looks to me like a delay valve missing its upper section.
The 8A564 coolant temp switch threads into this location, how many non CA vehicles have y'all non CA residents seen this part installed on?
Old Jul 6, 2011 | 07:50 PM
fmc400's Avatar
fmc400
MSEE
I have a 400 in a '73 Galaxie that came from the Twin Cities plant with the exact same fitting, in what seems to be the exact same spot. I will try to snap a picture of it.
Old Jul 6, 2011 | 07:57 PM
fmc400's Avatar
fmc400
MSEE
Here's mine. I have it capped off, but under the cap is a barbed nipple. Both the 351M and 400 are dry-intake motors, so no coolant temperature switches in the intake on these.
Old Jul 6, 2011 | 08:03 PM
devino246's Avatar
devino246
Old Jul 6, 2011 | 08:12 PM
vtjvt's Avatar
vtjvt
My 78 with 351 has the same fitting also, just cap it off.
Old Jul 6, 2011 | 08:16 PM
devino246's Avatar
devino246
Ok, just making sure it wasnt messed with by the PO like so many other things on this truck. thanks guys!
Old Jul 6, 2011 | 08:32 PM
ranger429's Avatar
ranger429
Looks the same as the one posted in the first picture.
Correct, the ported vacuum switch went in the thermostat water outlet.
cscott952
Mar 11, 2014 10:24 PM
mntg718
May 28, 2008 01:45 PM
intensecaraudio
Aerostar
Jan 1, 2008 03:01 AM
