Which distributor cap?
Old Jul 4, 2011 | 05:18 PM
buckshot1822's Avatar
buckshot1822
Hey guys, I am trying to eliminate my missing problems on my 77 F150 351M, as far as I know it has the factory distributor, and before I try and get the distributor loose(its ceased in the block, and I will probably bust it) I want to try and replace the cap, and rotor and see if that makes a difference......
which one of these cap kits would I need? Or something else better?
MSD Ignition 84085 MSD Ignition Rynite Distributor Cap and Rotor Kits
MSD Ignition 8414 MSD Ford V8 Cap Kit
also, my plug wires are pretty new, if I go with one of these caps do I need different plug wires or anything?
Old Jul 4, 2011 | 07:39 PM
fmc400's Avatar
fmc400
MSEE
Neither of those. Go to your nearest parts store and get a standard OEM-style cap for $10. It's just a piece of plastic.
Old Jul 4, 2011 | 08:29 PM
planehunter's Avatar
planehunter
I disagree, get a quality cap and rotor with copper parts. Also use quality plug wires and copper plugs. You don't need top of the line, just copper quality.
Old Jul 4, 2011 | 08:31 PM
The Confederate's Avatar
The Confederate
Very true, and brass parts does the trick, too.
Old Jul 5, 2011 | 06:04 AM
buckshot1822
I agree that I want one with brass, or copper contacts............so, which one of the above would work if anyone knows?
Old Jul 5, 2011 | 07:02 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I agree with fmc400 on this. That aside, if you have the male prong DSII cap now, your plug wires will work. If it's the DSI female connections then no. Personally, I never buy from Jegs due to the fact they tack on a "handling" charge to each order. Summit beats them everyday.
Old Jul 5, 2011 | 08:46 AM
fmc400's Avatar
fmc400
MSEE
Copper vs. other contact materials is not my point - my point was it makes no sense to spend almost $40 online on a "performance" distributor cap when that's clearly not the goal here. My "$10" reference is simply an allusion to the fact that the basics will do here. If a copper-contact cap costs more than $10 in practice, then by all means go for that. Whatever the end result ends up being, this problem can be solved by a quick trip to Napa.
I don't know if an MSD cap will fit on a stock Ford distributor, because it doesn't matter - we're telling you that there is no reason to do this because this is a commonly stocked item at any parts store, and is very straightforward. If you're under the impression that switching from an OEM distributor cap to an MSD cap will solve a misfiring issue, then you are mistaken. But, it's your truck.
Old Jul 5, 2011 | 10:31 AM
buckshot1822
I plan on calling all of the local shops today, and checking what they have........I realize that these MSD caps have no advantage over any other cap I can get locally.......I just dont want a cap with aluminum contacts thats all....
Old Jul 6, 2011 | 08:38 PM
buckshot1822
Just letting you guys know, I think I got the issue taken care of..........I bought an Echlin cap and rotor from Napa...........which by the way ended up costing $35.......
This helped the problem a lot, and then today I clamped visegrips on the distributor shaft, and worked it loose with a hammer(It had been soaking in PB Blaster for 3 days)..............I advanced the timing a little bit, and that seemed to pretty much completely eliminate the backfiring issue I had.......
Old Jul 6, 2011 | 08:51 PM
fmc400's Avatar
fmc400
MSEE
That's great; glad to hear you got it worked out.
oblivionnewtonjohn
24
Feb 12, 2015 06:34 PM
Lilryan
Nov 30, 2012 12:21 AM
76shortie
Feb 23, 2012 01:25 PM
joe f350
Jun 20, 2011 08:06 AM
410F-100
Dec 4, 2010 09:08 PM
