Smoking at interstate speed
Old Jul 5, 2011 | 06:27 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Intake gasket leak is *typically* accompanied by a noticable miss, particularly at idle.
Good suggestion, though. If the engine has a detectable miss at idle, that seems to go away once the RPM goes up a bit, it could be part/all of the problem.
Old Jul 5, 2011 | 08:58 PM
PA74F250's Avatar
PA74F250
I had absolutely no misses whatsoever. The only thing I noticed was slightly more power because of the lean condition. Also the puffs of smoke after a good bit of oil was pumped to the top.
All it takes is for someone to have the intake off once and not sit back on properly screwing up the gasket. It's easy to do with the weight of them.
Jarrett Campbell
20
Nov 17, 2015 07:28 AM
Atlee
2009 - 2014 F150
Apr 17, 2015 05:56 AM
Monty Simmons
Mar 3, 2014 08:05 AM
acarter92
Sep 9, 2013 05:05 PM
abyars111
Jan 9, 2012 06:55 AM
