Fuel Mileage 23.2
Fuel Mileage 23.2
February 19, 2014
2006 Ford F250 6.0 4x4 four door
Well, the latest fuel mileage figures are in and the average city/highway (60% city / 10 % interstate / 30% country, no load) mixture is 20.6 mpg.
Another 400 plus mile trip on interstate resulted in 23.2 mpg.
verified via manual calculation by filling tank all the way to the point one could see the fuel level.
NOTE: For interstate: I reset the computer after getting up to speed on the interstate and drove almost 5 hours straight early morning hours - no traffic. The only non-interstate mileage occurred when getting off interstate and driving to gas station. The mileage was 24.1 just after coasting off interstate to exit to go to gas station but dropped to 23.2 during the 3 miles driving to the gas station (and I went through a mini bank).
Basically a stock truck except:
(1) new head gaskets although OEM;
(2) heads have been milled 12/1000 and 14/1000 with no valve work;
(2) shorter push rods;
(3) EGR Delete;
(4) 4" exhaust all the way back, no cad;
(5) stock turbo
(6) custom tune
Mileage is a little better than before the motor work.
I believe milling the heads 12/1000 and 14/1000 may have actually improved mileage. I suspect the combustion chamber now creates a more efficient burn, some how, perhaps by favorably changing the stoichiometry of the fuel air mixture. Or it could be the 4" exhaust or perhaps the custom tune (or all of the above).
Point is, one can get 24 mpg out of these trucks with no load driving down I95 to Florida from NC.
(3) EGR Delete;
(5) stock turbo
(6) custom tune
Small change in volume, for sure, but still a change.
One thing for sure, milling the heads does not appear to be a bad thing at the moment with regard to mpg.
If the machine shop truly did their job correctly, they should have set valve recession within specs so there would be no change in compression. If I took a diesel head to have milled and the shop didn't suggest recession change or at least check it, I'd turn around and walk out.
We did use shorter push rods (new OEM push rods) but such simply takes some preload off.
But I do not believe the coolant was getting into the cylinders. I believe the compression of the air fuel in the cylinders was pressurizing the coolant and causing it to puke.
So good point, better compression from new OEM head gaskets probably affected the stoichiometry of the fuel air mixture far more than milling the heads.
