Sponsored by: Real Truck
Stranded by started
Old Jul 4, 2011 | 06:30 PM
venom50svt's Avatar
venom50svt
Stranded by started
Hi, Today gettingready to come home from vacation and went to start my f350-7.3 and NOTHING, All the lights go on and not even a click from the starter..... I checked the power to the starter--ok, banged on the starter, and tapped the soilonoid---nothin,,,, Checked fuses, any sugestions..thanks--truck was left behind....
Old Jul 4, 2011 | 06:36 PM
RUNVS's Avatar
RUNVS
What was the address??? haha!! Sorry to hear that. Could be a bad wire or bad solenoid as well!! Went through many starter solenoids on my '87!!
Old Jul 4, 2011 | 06:41 PM
F350-6's Avatar
F350-6
Try starting it in neutral. Not even a click sounds like the neutral safety switch is kicking in.
Old Jul 4, 2011 | 06:42 PM
venom50svt's Avatar
venom50svt
Yes I tryed to jump it,, All dash lights and glow plug solonoid was powered up. Its just when I went to start it there was nothing... no clicking from the started.... all the fuses were checked all were good...Didn't know if it was a relay and if it was which one is it..... Oh and it was at my camp,, hahah
Old Jul 4, 2011 | 07:13 PM
venom50svt's Avatar
venom50svt
Yea I tried that also.
I thought I would ask the group because the only thing I can think of is the solinoid on the starter.
The truck was parked on the side of a bank with the driver side on the high side. Don't know if the angle has caused the neutral switch to get stuck....hmmmmm don't have a clue
Old Jul 4, 2011 | 07:31 PM
Kajtek1's Avatar
Kajtek1
If it is manual -check the clutch switch. There is much more in modern engines that affects the starter than just battery and ignition switch.
Good luck
Old Jul 4, 2011 | 08:33 PM
Dave Tyler's Avatar
Dave Tyler
I have a 99 F250 PSD with same thing. Where is the Neutral Safety Switch? Just bypass or what? Nothing trys to start, went back today and after reading 20 pages worth on FTE this morning, did locate the starter relay on the passenger fender and went under and tapped on starter and starter sol. Where and what to try and bypass? Thanks. Dave
Old Jul 4, 2011 | 08:51 PM
venom50svt's Avatar
venom50svt
In the days with a soilenoid on the fender well you use to be able to cross the posts with a screw driver and it would crank the starter--- not now! I hate the new crap
Old Jul 4, 2011 | 09:23 PM
Dave Tyler's Avatar
Dave Tyler
The soilenoid is still there. Can you jump it or not? The one on fender well. Dave
Old Jul 5, 2011 | 03:58 AM
venom50svt's Avatar
venom50svt
I will try to locate it. I know there is one on the top of the engine but I believe that is for the glow plugs, I maybe wrong,
Old Jul 5, 2011 | 08:08 AM
Dave Tyler's Avatar
Dave Tyler
There are two on top of motor, for glow plugs?, the one on the fender well, passenger side, goes to starter solenid(on top of starter.) Dave
Old Jul 5, 2011 | 09:24 AM
lakedweller's Avatar
lakedweller
Have you checked the cable to the starter. My 98 F150 had the same problem and the lug that connected to the starter was corroded and almost gone. They replaced the lug and walla it worked.
Old Jul 5, 2011 | 05:59 PM
Dave Tyler's Avatar
Dave Tyler
Went and towed the the truck home. Tried the voltage on batteries, 12.53, two years old, crawled under truck and sparked the solenid on the starter, lots of fire but that was all. Also tapped the netural safety switch on side of trans. Nothing yet. Should I go ahead and replace the netural safety switch? Not sure what to do but need to get running. Thanks for reply. Dave
Old Jul 5, 2011 | 09:22 PM
venom50svt's Avatar
venom50svt
Well I went and took the advise from you guys and looked for the solnoid.. Yup on the inner fender well on the pass. side. Well back in the day I use to jump that sucker--little post and power post to the starter... It cranked---- I charged up the batt: turn the key on and it fired up... This allowed me to get this jessi home where my tools are....So tomorrow i am replacing that thing with a new one and I should be all set.....I will let cha know how it settles out..
Thanks for the help from you all, I appreciate it very much...
More to follow tomorrow......steve s.
Old Jul 6, 2011 | 09:00 AM
RUNVS's Avatar
RUNVS
Glad to hear you got her fixed!!! Well, temporarily at least!! I used to plow with my '87 and used the Ford starter solenoid for my Meyers plow. I used to have to carry around a spare solenoid in the glove box because with two of those on the fender, it wasn't long before I had to replace one of those things!!
Oh, and the aftermarket ones were like $12 and the Meyers were like $50!!
