Figuring out my 51' F1
Also, what exactly is this?
<img src="http://i805.photobucket.com/albums/yy333/TheMiracles79/underglove.jpg">
Finally, how difficult is it going to be for me to remove the cab and bed? What type of equipment am I needing to do this? Thanks for all the help FTE!!
<img src="http://i805.photobucket.com/albums/yy333/TheMiracles79/truck.jpg">
The "super" is previous owner installed. Non-stock. That's why you couldn't find any reference to it. Could be from a Buick.
Your center picture is your heater box, with defroster ducts on top.
It's not hard to remove the bed and cab. It's just bolts to remove, and then 'lift, and separate' as Jane Russell used to say. ;p
Get about 4 friends to stop by after you get everything unhooked. There is a pretty good write-up in the Dennis Carpenter catalog on how to replace the cab mounting pads and bushings in the rear swing-arms. Here's the link...it is a big .pdf file, so depending on your internet connection speed, it could take a couple of minutes to load.
http://www.dennis-carpenter.com/pdf/48-56_2010.pdf
The bed is easier and lighter than the cab, but you can use the same friends to help you lift that off as well.
davewild
349
08-30-2020 10:17 AM
puddle
51
02-26-2017 01:35 PM
1andonlywhitie
07-16-2011 03:25 PM
Milwaukee1979F150
01-04-2010 05:28 PM
