DUI wiring
Old Jul 4, 2011 | 12:20 PM
co425's Avatar
co425
DUI wiring
Hey all. I'm at work and trying to get this worked out in my head. I know the Davis unified ignition hei distributer "DUI" only needs one hot lead to run. I am running a relay with a fused hot right from the battery to power it. However I still want to trip the relay from the ignition switch. So if I am thinking correctly? I need a circuit that is hot in start and run to keep the relay tripped. Is there a circuit on the ignition switch that stays hot with both. Or do I need to run a hot in run from the switch, and a hot in start from the I terminal on the solenoid to my relay to keep it tripped. Maybe there is a better way that i havent thought of. Thanks in advance.
Old Jul 4, 2011 | 12:33 PM
bigdaddys76's Avatar
bigdaddys76
Curious as to why you dont just use the hot from the ignition switch that goes out to the coil? Why the relay?
Old Jul 4, 2011 | 01:12 PM
1977f250's Avatar
1977f250
Bigdaddys got it. Use the old +coil wire to trigger the relay.
Old Jul 4, 2011 | 01:20 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
[quote=bigdaddys76;10534877]Curious as to why you dont just use the hot from the ignition switch that goes out to the coil? Why the relay?[/quote]
Cause it needs full 12v. Stock coil wire runs thru a resistor wire dropping voltage. It's either the relay or run a seperate 12V switched source.
Old Jul 4, 2011 | 01:48 PM
co425's Avatar
co425
Ok so the hot from the switch to the coil is always hot in start and run correct? I just want to make sure. If so I will use that to trip my relay.
Old Jul 4, 2011 | 01:53 PM
co425's Avatar
co425
You also are supposed to use a 12 gauge wire. Easier to run it from relay and make sure it's a full twelve volts on a new circuit.
Old Jul 4, 2011 | 02:22 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
In start position it bypasses the resistor wire and gives full 12V to start, in the run position, it goes thru the resistor wire lowering voltage.
Old Jul 4, 2011 | 02:46 PM
co425's Avatar
co425
Cool thanks. I will be using that wire. After I get it all in I'll remove the rest of the dura spark wiring.
Old Jul 4, 2011 | 03:01 PM
1977f250's Avatar
1977f250
Yes it will trip your relay, It ran your old coil. Run a 10/12 ga wire from the battery side of the starter relay, I put a in line fuse in there, to post 30 on your new relay, ground post #85, 10/12 ga wire from post #87 to your HEI clone, put your old pos coil wire on post #86. Now you have a clean 12 volts to the Hei and no new strain on your trucks wiring and the new relay will only need a trickle of power from the old coil wire to trip the new relay.
Old Jul 4, 2011 | 03:18 PM
Paul49's Avatar
Paul49
There's an unused plug (on my '75) on the wiring harness that runs along the firewall in the engine compartment. It is right behind and above the right hand valve cover. I assume it is for the air conditioner that my truck does not have. That plug is hot with the ignition on, but I don't know about in the "start" position. I think some circuits are switched off in the "start" position, and this could be one. I used it to power (throught a relay) an add-on electric choke that one of the previous owners installed. It's a handy place to pick up power for a relay control circuit.
Paul
Old Jul 4, 2011 | 03:37 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Don't scrap that Duraspark wiring! If you're not going to keep it I'll take it off your hands. I do conversions to the Duraspark all the time.
Old Jul 4, 2011 | 03:42 PM
co425's Avatar
co425
Sorry I'm keeping it for a 390 I'm building up for my dads ****** rat rod. I already have the distributer so I need the harness and the box. I'm just converting my ignition in my highboy with a 460.
A.j. Smith
Oct 29, 2015 03:45 PM
53FOPAR
Feb 12, 2015 03:00 PM
KsCop
35
Aug 11, 2014 03:25 PM
wezol5484
Apr 13, 2010 01:13 PM
Pkupman82
Electrical Systems/Wiring
Jan 13, 2010 01:07 PM
