E40D question
Old Jul 4, 2011 | 06:53 AM
tony. b's Avatar
tony. b
E40D question
Hey guys.94 f150 5.0 4X4 E40D. I was having hard shift problem, swapped psom and that took care of it. I think something still isn't quite right. Shifts smooth now but, seems to shift out of first way early and I really have to get into the pedal to get it back to first,also seems to stay in third alittle too long sometimes. feels good otherwise. Did some reading about tps adjustment and mlps just wanted to run it by you guys. The previous owner did replace the tps right before I bought it. Thanks for any input.
Old Jul 4, 2011 | 07:19 AM
subford's Avatar
subford
Did you set the new PSOM for your tire size?
Old Jul 4, 2011 | 07:26 AM
tony. b's Avatar
tony. b
The truck I pulled it off of had the same size tires but I guess its always a possibility that someone changed it along the way. I should probably start there. If I do a search will I find out how to program it? Thanks for the input sub.
Old Jul 4, 2011 | 07:45 AM
rla2005's Avatar
rla2005
What's a PSOM & how do I "P" it??? - FSB Forums
Old Jul 4, 2011 | 10:16 AM
tony. b's Avatar
tony. b
Ok, just took truck to the store and I'm pretty sure I need a rebuild, slipping bad!!! Still moves ok in first and reverse but that's about it. Fluid level is good and doesn't smell or look burnt. Didn't feel like it was slipping before today, had it out on the highway last night all seemed fine. Then today it started. Grrrrrrrr! That's $1700 I don't have. I hate autos, this is the first one I ever had.all my other trucks were standards.
Old Jul 4, 2011 | 10:25 AM
chris11376's Avatar
chris11376
that sux. 1700? you buying a new tranny? you can get your rebuilt cheaper than that. call around you should be able to get a free estimate somewhere
Old Jul 4, 2011 | 10:37 AM
tony. b's Avatar
tony. b
That would be cool if its cheaper than that, since its a holiday I guess I won't be able to do anything about it till tomorrow. Any tips on what I should look for in a rebuild, upgrades,ect...
Old Jul 4, 2011 | 10:42 AM
subford's Avatar
subford
I think you need to go and take a look at the TPS and make sure the voltages are are about right in that one he put on.
Also check the wiring to the TPS as this will cause the transmission to slip and change gears at the wrong speeds.
Old Jul 4, 2011 | 11:04 AM
tony. b's Avatar
tony. b
I did a search on how to test tps but I'm alittle confused some thing I found said ground meter to battery some said to the Sig return wire and do I probe the wires coming off the tps its self or the truck side of the harness.
Old Jul 4, 2011 | 11:18 AM
tony. b's Avatar
tony. b
It does seem strange that I didn't feel any kind of slippage and then all of a sudden its slipping bad.
Old Jul 4, 2011 | 11:52 AM
subford's Avatar
subford
You should use the Sig return wire to make sure the circuit is complete to the NEG post of the battery but they both are the same ground point.
Old Jul 4, 2011 | 02:58 PM
tony. b's Avatar
tony. b
I just checked voltage to the tps and I got 1.0 at closed and 4.4 wot. With a smooth increase closed to open. But while doing that I found out my fan clutch is frozen. It's only about 4 weeks old. I did notice that while I was driving it sounded like it was engaged. How much power would that being froze up take from that 302? Enough that with the noise and loss of some power I could mistake it for slippage? I didn't drive it far earlier so its hard to tell now. I'm thinkin I should start there and see, needs fixed either way.
Old Jul 4, 2011 | 03:59 PM
subford's Avatar
subford
Sounds good to me.
Old Jul 5, 2011 | 07:57 PM
tony. b's Avatar
tony. b
Just updating, I hate when people don't let us know what happens. Changed the fan clutch and all is good. Kinda feel like an idly thinking trans was slipping but it was very deciveing especially on a short ride while I was being easy on it. Since I was having that hard shift problem my mind just immediately went to trans problem.oh well, not the first time in my life I looked stupid, sure it won't be the last.
Old Jul 6, 2011 | 07:58 AM
Boz86's Avatar
Boz86
Those coincidences will take you down some weird paths.
kadassa
Jan 16, 2015 03:03 PM
1badshovel
Jul 1, 2011 11:00 PM
jdemaris
Jul 13, 2007 02:48 PM
rpatrick
22
Mar 1, 2007 01:25 PM
dieselbogging
Sep 15, 2006 05:32 PM
