1999 4.0 Ranger .Could a faulty TPS effect my air conditioner .Truck runs good ,air works on an intermittent basis,compressor cycles on and off about every 10 seconds.Thanks in advance.
Could be low on R-134, or maybe a faulty low pressure switch, sounds like the IAC is working ok if it idles up when you switch the A/C on.
Is cooling wimpy?????
Any oily signs of a leak around any of the A/C line fittings, or the compressor????
The system refrigerant should be pumped out & recharged by the specified weight of R-134 listed on the under hood label, Don't use one of those products with a sealant in it.
