XZTS harness
Old Jul 3, 2011 | 03:14 PM
simsbud's Avatar
simsbud
XZTS harness
what is a XZTS harness and were is it located?? read online that some guy unplugged it cleared his p0237 code and it fixed the issue
Old Jul 3, 2011 | 03:47 PM
dchamberlain's Avatar
dchamberlain
Can't say I've ever heard of an XZTS harness. I can say that I've never heard of disconnecting something to make it work. P0237 is MAP sensor circuit low. That would indicate a problem with the MAP sensor or the wiring to the MAP sensor.
The MAP sensor is attached to a triangle shaped adapter in the rear passenger side of the engine compartment. It has a three wire connector and a hose that goes to the intake manifold.
What issue are you trying to solve? Other than the code.
Old Jul 3, 2011 | 04:06 PM
simsbud's Avatar
simsbud
Thanks got that issue squared away now its throwing a p2285 injector control pressure sensor circuit low, wasnt throwing that code before
Old Jul 3, 2011 | 05:49 PM
texans's Avatar
texans
you can't fix codes by just unpluging a sensor.
devils toy
Jul 6, 2015 01:36 PM
69issofine
Jul 3, 2015 08:41 PM
Austin Steinmann
Apr 30, 2014 01:56 PM
revans9295
16
Mar 27, 2014 06:09 AM
TomThrall
May 22, 2002 10:02 PM
