1978 - 1996 Big Bronco
dome/ map lights
Old Mar 28, 2003 | 04:40 PM
yosemite's Avatar
yosemite
dome/ map lights
My dome light works, but not the map lights. Bulbs are fine. I saw the black/lt blue wire for the dome light and it gets power(obviously), but the light green wire for I'm guessing the map lights isn't getting any power at all. Where does this wire come out? Down by the parking brake? or does it run somewhere else? And where is the ??relay?? that the wire gets power from? I may have to rerun a wire, but need to know where to connect it to before I do that.
Or am I missing a wire??
Brian
Old Mar 29, 2003 | 10:25 PM
steve83's Avatar
steve83
dome/ map lights
That wiring goes under the driver's threshhold behind the shoulder belt reel & up inside the B-pillar. It usually corrodes horribly just below the reel.
Old Apr 5, 2003 | 01:12 PM
kilted_drummer's Avatar
kilted_drummer
dome/ map lights
I will check that also...I have the same problem, dome light works like a champ, both little lights are no-go's. You say it corrodes behind the seatbelt reel eh....go to look now. Thanks.
John
90 Bronco
Old Apr 5, 2003 | 09:03 PM
yosemite's Avatar
yosemite
dome/ map lights
Let me know what you find. I need to figure out what relay/connector a new wire needs to connect to and where it is. Probably end up running another wire.
I know if it's behind the seatbelt it's probably corroded as I had cracks in the rain gutter(as every Bronco I've ever seen has) that let water in the truck all the time. Used Bondo to fix that, but it probably won't hold. I'll just apply some silicon to it every once and a while when it starts cracking again.
Brian
Old Apr 6, 2003 | 03:10 PM
kilted_drummer
dome/ map lights
I dug into this a little, to no avail though. I have gone this far without them, guess I can keep going...lol. Though I did break the ugly yellow lense that covers the dome light, so I changed the bulb...wow what a difference of lighting inside the truck without that yellowed lense.
John
Old Apr 6, 2003 | 03:28 PM
Des's Avatar
Des
dome/ map lights
My 89 map lights don't go on unless the head lights are on.
Old Apr 6, 2003 | 03:34 PM
kilted_drummer
dome/ map lights
I am going to go try that...with headlights on. I dont think I ever tried it that way.
Old Apr 6, 2003 | 03:51 PM
kilted_drummer
dome/ map lights
headlights on op-test...unsat...lol sigh, oh well as just posted I dont use them.
Old Apr 6, 2003 | 08:51 PM
Mary_Kate_Olsen's Avatar
Mary_Kate_Olsen
dome/ map lights
My map lights don't work either. last year before the snow I found the 'light green wire' behind my b-piller was broken (looks cut). Well it got really cold the next day and it has been too cold sense then to fool around with it. I think it should be fixed when I reconnect that wire. But its a tight fit and I don't know if I can crimp or solder the wire back together.
Old Apr 6, 2003 | 09:52 PM
kilted_drummer
dome/ map lights
How did you look behind the B pillar...it is sealed. Did you see it lower? ugghhh. This is one that will kill me..lol even thoug it isn;t that big a deal.
Old Apr 8, 2003 | 08:47 AM
Mary_Kate_Olsen
dome/ map lights
The break in the wire was at the bodom of the B-piller. Down behined where the seatbelt rolls up. Just remove the plastic thing and pull the carpet back.
There are a few wires running up the b-piller and all of mine looked perfect except the light green wire. Thats why I think somebody cut it. I have no idea why they would cut it though.
I wish it would warm up so I can try fixing it. We just got three more inches of snow last night. Its April, STOP SNOWING!
Old Apr 8, 2003 | 06:40 PM
kilted_drummer
dome/ map lights
Thanks Mary Kate.... I found the stupid light green wire under the seatbelt reel. The moisture from sitting in the trough for 13 years caused to sire to break at the connector. I slpiced it back together and woohoo, they both work again. While insignificant in life overall, it was a milestone for my truck.. Thanks again
Doubleubar
Feb 24, 2016 06:33 AM
BLACKHAWK_1989
Feb 12, 2016 03:34 AM
Still_ridin_clean
6.4L Power Stroke Diesel
Jul 19, 2015 11:46 PM
papazig4726
Mar 6, 2015 06:07 PM
84StraightSix
Aug 31, 2014 12:35 PM
