Oil pressure sender help
Old Jul 3, 2011 | 01:18 PM
Bagbyknoter's Avatar
Bagbyknoter
The old oil pressure sender on my 85 f150 is stuck and ive tried just about everything i know how to do to get it off. Is there some kinda stupid simple trick to get it off or what. Any help will be appreciated
Thanks,
Jonathan
Oh BTw it has an 81 engine in it if it makes any differance
Old Jul 3, 2011 | 04:03 PM
ctubutis's Avatar
ctubutis
A 9/16" open-ended wrench has always worked for me.
Old Jul 3, 2011 | 07:40 PM
dustybumpers's Avatar
dustybumpers
try a little heat
Old Jul 3, 2011 | 07:47 PM
khadma's Avatar
khadma
Carpenter Local 745
Take a break from it.
and use suggestions above^^^
and some penetrating oil.
Old Jul 5, 2011 | 10:23 AM
nstueve's Avatar
nstueve
pb blaster
Old Jul 5, 2011 | 12:07 PM
Bagbyknoter
ok I soked it in pb blaster for 2 days and tried to break it lose today, and it broke about an half inch from the block. What now
Old Jul 5, 2011 | 01:05 PM
Wyowanderer's Avatar
Wyowanderer
Weld a nut that fits over the part left over (if you don't weld, have someone do it for you): push a block of canning wax against the junction between engine block and the old stud, and let it cool. When it's cool, it ought to turn out. You'll need someone who is a good welder to pull this off. The wax will wick between the stuck nipple and the block and act as a lubricant.
If it breaks off again, you'll need to use a bolt extractor. I use this one; I've had much better success with it: No. 10 Screw Extractor Set - RIDGID Professional Tools
Good luck.
Old Jul 5, 2011 | 06:33 PM
ctubutis's Avatar
ctubutis
The Art of Extraction
Old Jul 6, 2011 | 10:06 AM
Bagbyknoter
OK i hear the sugestions of welding, But can you weld on brass. Cause this thing is made of brass
Old Jul 6, 2011 | 06:08 PM
billt28's Avatar
billt28
You will need top braze brass. Welding is too hot and will melt it.
Old Jul 9, 2011 | 08:14 PM
Bagbyknoter
Ok i got the old one off and the new one on.
I had to take the P-rod cover off, and there was a spot on what was left of the sender for a 9/16 wrench just like ctubutis said. Thanks for all the advice guys
SVTDriver97
Jun 10, 2014 06:21 PM
d-day
26
Apr 17, 2014 07:37 PM
Ford_Man_302
May 12, 2004 04:53 PM
opporll
Mar 7, 2004 08:12 PM
Andy63
Jul 20, 2002 07:38 PM
