variable oil pressure sender
Old May 12, 2004 | 12:10 PM
Ford_Man_302's Avatar
Ford_Man_302
Ok ive got a few questions to ask and any insight if possible. I have a 1990 ford f150 with the 302 i know after 87 or so they started adding in the on/off type senders instead of the bell shaped variable oil pressure type my question is if i put the bell shaped type in place of the origanal idiot sender will it work right? I know there is a 20 ohm resister behind the dash that needs to be by passed so it will read right. I have already purchased the pre 87 type sender. I was wondering if any body had some pics of where the resiter on back of the gage in dash is located and what they did to by pass it so the pre-87 sender works. Any help would be greatly appreciated thanks.
Old May 12, 2004 | 04:53 PM
gatesj's Avatar
gatesj
Worked perfectly on my '91 and your '90 is identical wiring diagrams. Just solder across the resistor that is on the back of the panel. It is the only resistor near the oil pressure gauge, at least on mine (speedometer and four gauges, cheap model). Not sure about the cluster with the tach. Then just change out the sensor.
This is obviously for a newer truck but it's similar:
https://www.ford-trucks.com/contents...re%20Gauge%202
I'm almost positive '90 is the first year for the idiot gauge. 87-89 had a different wiring diagram than 90-91 even though it was the same body style. I don't think there's a resistor in the wiring diagram for 87-89.
linckeil
13
Oct 2, 2013 11:10 AM
trackenator
Mar 17, 2011 10:02 AM
tip49
Jul 13, 2010 09:39 PM
antiqueynot
Jul 19, 2008 07:01 AM
newfordguy88
Aug 4, 2005 11:01 AM
