3g alt.
Old Jul 2, 2011 | 12:25 PM
oldfordcoupe's Avatar
oldfordcoupe
3g alt.
with the eng. running i have a little over 14 v with a load of say lights it drops to around 13.5-7 v wipers on it drops again to 13 v with tha air on it drops to 12.5-7 v and my temp ind. goes up past 210 . turn the air off and temp drops to 200 or so turn lights off temp goes down to 185-190 with more items on my temp ind goes up more byt the voltage drops more it should not drop that low with a load should it ?????
Old Jul 4, 2011 | 08:26 AM
Franklin2's Avatar
Franklin2
It may be your idle rpm or your belt tension. Make sure the belt is tight. Then while doing your testing, raise the idle of the engine a little bit. It may be turning too slow. If you have retro-fitted this onto a older engine with the original pulleys, you may need to change the pulleys on the engine if you have that option. If you compare a 60's or older engine to a 70's-up engine, you will notice the pulleys are made to turn the fan and the alternator faster, to help with cooling and all the electrical accessory loads.
scooter71
3.8 & 4.2L V6
63
Jul 25, 2018 11:27 PM
fishman002
Sep 7, 2011 10:36 PM
dkeeney
Jan 1, 2005 11:00 PM
Justntimeracing
38
Sep 28, 2004 07:46 AM
curtwalk
Sep 15, 2004 08:40 PM
