Electric Fans
Old Jul 2, 2011 | 08:45 AM
Boba Fett's Avatar
Boba Fett
Electric Fans
Anybody running an electric fan to replace the stock crank driven fan? What are you running? What about wiring?
Old Jul 2, 2011 | 09:14 AM
78 PEB's Avatar
78 PEB
Do a search in this forum for "Mark VIII fan" You'll come up with some good info.............
Old Jul 2, 2011 | 05:24 PM
co425's Avatar
co425
The Mark VIII fan is the only way to go. I have mild 460 in this 90 plus weather I have yet to get over 190 degrees. Takes the worry out of sitting at lights or traffic.
Old Jul 2, 2011 | 05:39 PM
fordman75's Avatar
fordman75
I'm going with a Taurus fan on mine.
Old Jul 2, 2011 | 08:47 PM
akforceten's Avatar
akforceten
If you cant find a mark VIII fan they also came in 94-96 t-birds. Here's a pic of what your looking for.
And here's the pic of the mounting bracket I made
Hope this helps.
Old Jul 2, 2011 | 09:36 PM
jackofroses's Avatar
jackofroses
oh, so the back up fan from my 95 town car should be just the ticket....
my 78 f150 /302 came with what i think is a taurus fan .... its mounted with strapping , and the wiring is mainlined directly into the ignition switch......needs to be entirely rethunk
Old Jul 2, 2011 | 09:43 PM
Boba Fett's Avatar
Boba Fett
Thanks for all the info.... Ak..... Do you know the approx dimensions of those brackets you made? What about wiring? Is this something I can junkyard too? What year mark VIIIs?
Old Jul 2, 2011 | 09:45 PM
Boba Fett's Avatar
Boba Fett
And what about the Tarus fan? What years on them?
Old Jul 3, 2011 | 12:31 PM
akforceten's Avatar
akforceten
I will have to remeasure it I forgot the dimensions here is some more pics for you
The fan an bracket installed
The two relays for high an low
The 3G alternator conversion which is necessary for the amp draw from efan
Old Jul 5, 2011 | 08:52 AM
jsutton's Avatar
jsutton
Mid 90's Taurus's and Sables. You do have to make sure you get the fan from a car with a 3.8 engine. I have one from a Sable in my 77 with a 302.
As far as the wiring from the JY I'd say you can get some, but you need around an 80 amp continuous duty solenoid or breaker to run the high setting (which it seems like no one who does this conversion needs the high setting). I did get my regular relay's from a Taurus SHO and the sable, though.
junkkingranch
Sep 29, 2021 04:23 PM
jerryparks
Aug 22, 2015 07:46 PM
xc4jokestomper
22
Sep 2, 2012 06:28 PM
jkuhane
May 16, 2012 05:33 PM
