Having a idling problem
Old Jul 1, 2011 | 07:09 PM
DEAN95f150's Avatar
DEAN95f150
I have a 95 f150 351w e40d. I was getting a 211 error code, with all the symptoms that the pip sensor was bad. So. I replaced the distributor, set the timing to 10% with the spout connector off. The truck is running great exept when you come to a stop and sitting at the light, intermittently the idle will drop and fluctuate and almost cutoff. I know I need to check my codes to see if another one has popped up. But can someone just give me a ballpark idea of what the problem could be, or if there is a idle setting procedure I need to do?
Thanks,
Dean
Old Jul 10, 2011 | 08:04 PM
DEAN95f150's Avatar
DEAN95f150
Fixed it myself. Thanks a lot for all the help.....
Old Jul 10, 2011 | 09:23 PM
Gus Erickson's Avatar
Gus Erickson
What did you find? I just looked at this and my 93 acts the same.
Old Jul 18, 2011 | 09:30 AM
robertsblk70's Avatar
robertsblk70
What was the problem??
Old Jul 18, 2011 | 10:07 AM
Slip ford man's Avatar
Slip ford man
Me too, I'm heading out in the this crazy heat to try cleaning this, Ford Fuel Injection » Idle Air Bypass (IAB) to maybe get a better idle
DEAN95f150
Dec 3, 2013 09:47 PM
dean302
Jul 26, 2011 04:16 PM
DEAN95f150
Mar 17, 2010 04:43 AM
dean307
Nov 24, 2006 11:36 PM
Jimmy Dean
Mar 21, 2004 10:11 AM
