TPS and idle issues
Old Jul 1, 2011 | 05:03 PM
gorbulus's Avatar
gorbulus
TPS and idle issues
97 ford e 150 4.2L 180000 miles
I replaced the TPS after the diagnostic showed it was faulty and it tested bad. Now the idle surges, though it didn't do that before. The diagnostic showed a misfiring 6th cylinder as well and i'm not sure if it has anything to do with it or what I should do next. I could really use some help, thanks
Old Jul 1, 2011 | 05:19 PM
jimbbski's Avatar
jimbbski
Sometimes the TPS needs to be adjusted. I'm not sure on your application. I know that you will need a volt meter to do it.
Old Jul 2, 2011 | 04:33 PM
gorbulus's Avatar
gorbulus
There's no adjustment on the TPS itself. I fixed the misfire, but it's still surging. I've been told to drive it for 20 miles and let the CPU recalibrate, otherwise check vacuum hoses. we'll see
Mwitt
1997 - 2003 F150
Apr 19, 2012 11:06 AM
dwalls56
2009 - 2014 F150
Nov 23, 2010 09:05 PM
tim pennels
Mar 3, 2009 05:18 PM
TRUE IMAGE
Feb 2, 2009 02:19 PM
crimpton
Nov 6, 2007 08:28 PM
