stripped fuel filter cap
Old Jun 30, 2011 | 06:37 PM
Ian123's Avatar
Ian123
Just got done changing my fuel filters for the first time. Good news is I didn't get the dreaded 'diesel bath' or the infamous drain plug that never stops flowing (still don't understand that one). The bad news is my fuel pressure didn't change one bit so I'll be doing the spring upgrade and I sheared 3 of the points off the secondary fuel filter cap. The torque spec for it is 14 nm, a.k.a. 10 ft/lbs for those who live on planet earth, but my wrench only goes down to 20. Stupidly I thought that would be ok and stripped it before the wrench clicked. My question is will it be ok to wait until my next change to replace the cap or am I doing damage by leaving it like this (i.e. squishing the o-ring or pushing the filter too far down into the bowl)?
Old Jun 30, 2011 | 06:41 PM
texans's Avatar
texans
The thing I would worry about is sucking air through the cap. I personally never use a torque wrench on the cap just make sure it seats all the way down and snug it pretty good.
Old Jun 30, 2011 | 06:43 PM
william_04_x's Avatar
william_04_x
As long as you don't have any leaks, you're fine. But I have to ask, why not just change it out now?
Ian123's Avatar
Ian123
What would cause it to suck air? The cap is on tightly it felt like it was just about to 20 ft lbs when it stripped its probably at 18 or so
Old Jun 30, 2011 | 06:45 PM
Ian123's Avatar
Ian123
If my parents see one more package come to the house for this truck they might kick me out haha
Old Jun 30, 2011 | 06:49 PM
texans's Avatar
texans
If the cap is tight then you should be ok.
Old Jun 30, 2011 | 07:03 PM
Mich6.0's Avatar
Mich6.0
Why not just get an impact gun to finish it off
Old Jun 30, 2011 | 07:31 PM
dchamberlain's Avatar
dchamberlain
Cut the kid a break. He said this is the first time he's done it and we all started somewhere. I started on dirt bikes at 14 and broke more than a few things learning over 30 years.
Ian, as long as it's not leaking it's fine. The seal is the o-ring pressed between the cap and the aluminum housing.
For the future, all you need to do is tighten the cap down far enough that the lip of the cap meets the edge of the housing and make sure it's snug. This is true for both fuel filter and the oil cap.
Old Jun 30, 2011 | 07:40 PM
Mich6.0's Avatar
Mich6.0
Real sorrry just some humor
Old Jun 30, 2011 | 09:23 PM
rfdepew's Avatar
rfdepew
Boy, do I know the feeling, UPS stopped again today. I was not expecting anything
It was what did you order now and how much have you put into the truck?
I was lucky I turned and Said it's the Flea medication you asked me to order for the dogs.
Old Jun 30, 2011 | 09:51 PM
BLADE35's Avatar
BLADE35
but doesnt that one have a 1/2 inch drive for a breaker bar in center of the hex thats how I get mine off
its fine for now just have a new one next time you change the filter out if it dont have the 1/2 drive
I dont tourque that one either just seat it and tight
If you get into the moter get a tourque wrench that goes from 0-20 lbs
I guess its not IF but WHEN you get into the moter
lots of aluminum/plastic parts any more that strip easyier than that one did under less touque than that
Mine goes from 0-100 lbs but the first 12lbs is hard to feel the click Im thinking about a digital one TQ Wrench
anyone thats really ever wrenched alittle has done something like this dont feel bad just join the club
Old Jun 30, 2011 | 11:28 PM
texans's Avatar
texans
You shouldn't use that square hole on the cap. Always use a socket. Using the 1/2" square drive will result in a broken cap sooner or later.
Old Jul 1, 2011 | 05:25 AM
zhilton's Avatar
zhilton
Just for the sake of discussion, how much fuel is in the tank when you pull the drain plug? I try to time mine so that there's about 1/4 to 3/8 tank. I get pint of fuel into the drain pan and that's it. I wouldn't think the 4WD would make it any different.
You'll be ok, I'm not saying you can't crush the filter...but the plastic cap won't be the device you do it with. Now if you were running an aftermarket brand you could possibly twist it when you snugged the cap down...I've seen photos of that on here.
Old Jul 1, 2011 | 08:22 AM
Ian123's Avatar
Ian123
dont quit your day job
Yep I got the same questions but after I told them it was a maintenance item this time they weren't mad.
I was just slightly above a half tank
Old Jul 1, 2011 | 08:32 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I saw a thread a few weeks back where someone mentioned the fuel filters were indexed to the housing. I was planning to look at mine real close next time I change em. I didn't notice any notches or anything to line up before. You guys aware of anything like that on either filter?
