Ford IFS problems.
Old Jun 30, 2011 | 05:59 PM
mechmagcn's Avatar
mechmagcn
Unhappy Ford IFS problems.
After putting my 53 through the paces on the Tail of the Dragon last week I started hearing a bumping noise while turning a sharp corner or braking hard. Finally had time check it out and it seems that the upper control arm on the RH side has slipped. Pried it back out somewhat and tightened the bolt, will call for an appointment with my alignment guy next week. I recall him telling me that this was a common problem with these suspensions, and I have had one do it before on a 89 Town Car. Anyone else who is running a late 80s big Ford IFS ever had this problem? Any ideas to prevent it? I seem to remember my alignment guy using a breaker bar to tighten these bolts before. Guess I'll just have to check them regularly
Old Jun 30, 2011 | 06:04 PM
Truxx1956's Avatar
Truxx1956
They must not be built to take turns like The Dragon's Tail Who would have thought? I probably should go over and do the Harley bolt tightening stuff on mine too. You know ride a while and then tighten up all the bolts.
Old Jun 30, 2011 | 06:09 PM
mechmagcn's Avatar
mechmagcn
You've almost got that right, but it's ride a while, unscrew the loose bolts, add a drop of Loctite and then tighten I was always told that Loctite was invented just for Harleys Mine sure seems to require it
Old Jun 30, 2011 | 06:16 PM
Truxx1956's Avatar
Truxx1956
See if you crossthreaded them you could avoid all that. Crossthread is the new Loctite
Old Jun 30, 2011 | 08:18 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Not just Fords either. The same thing happened to my Volare just after I had it aligned. I think if the alignment guys don't really crank down on those upper control arm bolts they can work loose...
Old Jun 30, 2011 | 09:24 PM
arrowheadfred's Avatar
arrowheadfred
now that ya brought it up my truck has a shimmy at 45 mph and go's away at 50. WHAT WOULD CAUSE THIS ?????
Old Jun 30, 2011 | 11:26 PM
lorolr's Avatar
lorolr
Tire pressure, caster or wheel balance? Hop or shimmy? Radials?
Old Jul 1, 2011 | 12:17 AM
arrowheadfred
MORE LIKE A HOP. YES new cooper tires. I was thinking i need to have it aligh again.
Old Jul 1, 2011 | 10:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Jeff, it may be worth replacing the bolts that loosened. If they get stretched, they won't hold torque. There are a lot of bolts on cars that really ought to be replaced routinely.
Old Jul 1, 2011 | 10:16 AM
mechmagcn's Avatar
mechmagcn
Ross, I was thinking the same thing. Just wondering if the control arm pivot shaft had "teeth" on the bottom side to prevent slippage? I don't remember
Old Jul 1, 2011 | 12:27 PM
carnut122's Avatar
carnut122
balance
I'd start by getting them re-balanced. Also make sure there's no run-out on the wheels/tires.
Old Jul 1, 2011 | 12:36 PM
Truxx1956's Avatar
Truxx1956
I believe you're right Jeff, I think they do have teeth that are supposed to help hold them in place. Of course the bolts are supposed to be tightened too I am not sure how deep the teeth are and how much they actually hold.
Old Jul 1, 2011 | 11:02 PM
mechmagcn's Avatar
mechmagcn
I'll find out about the teeth next Wed when I take it in for alignment. Also made sure the guy would have new bolts for it too. I have to replace the rear bearing in the trans and service it this weekend, so I'm not likely to have much time to miss cruising around in it.
oldracerjones
1961 - 1963 F100 Unibody
Jul 16, 2014 09:48 PM
oldracerjones
Jul 14, 2014 06:17 PM
NBC-Steve
Dec 25, 2012 09:18 PM
xc4jokestomper
Apr 19, 2012 08:34 AM
teg2_nv
Dec 21, 2006 01:13 PM
