Bushwacker project
Old Jul 29, 2011 | 07:07 PM
officer131's Avatar
officer131
All right back from the car show, and grandfather recovering quickly (all movement is back.
Here's what I did today:
Mounted the rear for fitment.
Trimmed the front and rear to fit the contours.
Cut the small front piece that would stop the door from opening.
[/URL]
[/URL]
[/URL]
As far as the piece that was cut from the front section on the rear flare, I'm going to find a piece of plastic and mold it to the curve instead of the spray foam. The idea of all the moisture is scaring me way to much. As you can see from previous posts already have an issue with the doors.
Old Jul 30, 2011 | 09:37 AM
jasonodsky's Avatar
jasonodsky
Originally Posted by officer131
still need to hunt down this rear piece for both sides. I can always order it to.
You can use the rear piece from the XLT. It is much smaller than the cladding. May even be the same part as the shortbed XLT, you'll have to ask your parts guy
Old Jul 30, 2011 | 05:33 PM
officer131's Avatar
officer131
Wow, two days in a row I get to work on something. It's amazing.
Alright today I continued on cutting and fab work for the rear pieces on both sides. I mounted the rear piece all by itself and was thinking about what I could use to seal the opening. I asked earlier about it in a previous thread, but I'm worried about the moisture back behind to put a foam sealer. I got the idea of acrylic. I went to the store and got a few pieces, and after I found out what the cost was I'm using it and not F'ing up.
Here are some pictures:
[/url] Picture above: Passenger side with flare fitted and front section cut.
[/url] Picture above: again passenger side flare fitted and front section cut off.
[/url] Picture above: formed piece of acrylic with contoured to the body line for a nice fitment and stability.
[/url] Same as above different angle. The gap/lip is due to me not wanting to heat the acrylic and form it. There are way to many curves and angle's. For added security I plan on screwing a 90 degree bracket from the inside of the acrylic to the bottom of the flare. You will only see it if the door opens or you look underneath.
[/url] Plain and simple, 90 degree glued and contoured.
Old Jul 30, 2011 | 05:42 PM
officer131's Avatar
officer131
I don't plan on using the cladding from mine since the rear section was all one piece.
I'm bouncing around the idea of mocking up some LED side markers and just fitting them in there. Depending on cost, because parts guy ed sells the pieces for $20 each which seems reasonable. Even buying them new I would still have to cut the new ones to fit.
Old Jul 31, 2011 | 06:59 PM
officer131's Avatar
officer131
Today I was able to get a few hours of work done on my project.
I started by sanding down my surface rust spots as you can see in the pictures posted above. Thanks Michigan and your salty winters. I coated the spots with primer. No pictures, sorry I think everyone knows what metal and primer look like together.
I finished off by filling what appeared to be small openings on the flares where I put the acrylic in. Trying to make the best connection as possible.
Trying to research it, but is the epoxy stuff paintable? It doesn't say on the package.
Old Aug 1, 2011 | 05:50 PM
officer131's Avatar
officer131
Besides taking apart and fixing my kids powerwheel, I did manage to paint the rear flare sections. I am going to wait and see the fitment with the small cut out pieces before forming the acrylic/painting them.
pictures speak for themselves.
[/url]
[/url]
Out of all the background clutter, my grandfather still knows were everything is.
Old Aug 1, 2011 | 06:54 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i wanna see them on! lol looks great!
Old Aug 1, 2011 | 07:30 PM
Toyman's Avatar
Toyman
Nice job Al. Keep up the good work! Glad grandpa is doing good.
Old Aug 1, 2011 | 11:06 PM
duck fan's Avatar
duck fan
Because racetruck
Don't know if you guys knew or not but Bushwacker has OE style fender flares for the Excursion now. I just stumbled across them the other day. No pocket style yet but its a step in the right direction. Riffraff Diesel: 'OE' Style Flares
Old Aug 2, 2011 | 05:47 PM
officer131's Avatar
officer131
Knowing my luck, Bushwacker wil come out with the pocket style ones by the time I finish. Pocket style gets the aggressive look and another .5" of coverage. They look plain to be, but yes a positive step in the right direction.
Today I put the nuts and bolts on as they are decorative pieces. Also put the strip of rubber on the flare prior to mounting. Pictures below are the flare mounted on every angle.
Pic below: Painted passenger flare in front of a 1940 Bantam roadster.
[/url]
Pic below: Flare mounted.
[/url]
Pic below: side view. You can see the added piece as I attempted to countour it to the body.
[/url]
Pic below: Side view. Sweet, almost there.
[/url]
Pic below: Driver side, and a closer view of the added piece for stability. In the corner of the window is my Michigan chapter logo.
[/url]
Pic below: passenger side. Since Bushwacker didn't make the pockets for the Ex, I had to buy the F250 ones. The direction say a little of trimming, but there was more than expected. As you can see there is a little gap near the body contour. Luckily the rubber helped out a bit.
[/url]
Pic below: Driver side. Again contour and rubber helped out. This side had a better fitment than the other.
[/url]
I am in the process of making a game plan to tackle the cut pieces to complete the curve into the doors. Having a hard time with what will work to hold the piece onto the door with limited mounting spots. I was thinking of boxing the piece in. I would do that by forming a piece of acrylic to the body flat and epoxy that between the two pieces that would be vertical to the body. It make sense to me, hopefully you understand or have a better idea. I'm open to listen.
Old Aug 2, 2011 | 05:51 PM
officer131's Avatar
officer131
Thanks. Grandpa is back to his stubbern self and told the doctors he was over medicated. All movement is back, just has to work on the strength part.
Old Aug 8, 2011 | 06:06 PM
officer131's Avatar
officer131
Weekend was a loss. Had to help ex-wife move out. No progress on the project.
Old Aug 9, 2011 | 09:17 PM
  #28
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i think they look great. the door sections will finish it off well!
Old Sep 5, 2011 | 07:09 PM
  #29
officer131's Avatar
officer131
Finally back into the swing of things......well kind of. Today I sanded down the lower door panels to remove the rust and for repairs.
I also made a template for what I will call the butt plate for the cut pieces. The piece I made is what I will be connecting the piece (bushwacker) to the door panel (3m tape, or some sort of glue). What I did was take a piece of cardboard, place it against the door (opened) and cut a pattern. I then took a piece of 2x4 and transfered it onto the wood. I used the bandsaw and cut the piece of wood to the curvature of the door. Lastly, I took the formed piece of wood and started to lay the acrylic over top and used some heat to bend it. That way I will the the maximum amount of surface to adhear to the door.
I will post pictures later.
Old Sep 5, 2011 | 07:58 PM
  #30
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Can't wait to see it, sounds like you put a lot of thought into it.
