Got my DP!
Old Jun 30, 2011 | 07:37 PM
big poppa's Avatar
big poppa
Doesn't Isspros have two different pyro gauges for post or pre turbo??? I though when ordering mine the place asked if I was going post or pre turbo so they can send me the right gauge. You might have a post turbo gauge if my memory serves me right. And congrats, enjoy.. I love my DP, couldn't imagine life without it....
Old Jun 30, 2011 | 07:40 PM
Crewcab Turbo's Avatar
Crewcab Turbo
The sensor they sent me did have the big clamp and didn't fit on the up pipe. Had to use a smaller one.
Old Jun 30, 2011 | 08:15 PM
zx250's Avatar
zx250
Of the next Riffraff East
Something is way off, You can't burn diesel fuel at only 100 degrees. Are you clamped on or did you drill and tap?
Old Jun 30, 2011 | 08:17 PM
Crewcab Turbo
I am clamped on, no drill and tap.
Old Jun 30, 2011 | 08:35 PM
zx250's Avatar
zx250
That could be the problem. May need to clean it and reclamp it. You should be at 300 idling.
Old Jun 30, 2011 | 08:40 PM
Crewcab Turbo
Mine has an exhaust gasket between sensor and pipe so I would assume it's not meant to be grounded?? Not sure?
Old Jun 30, 2011 | 08:43 PM
Crewcab Turbo
Wish I had $150 and I would just buy a new pyro Gage and it would fit in my pillar mount and would hopefully work correct!!
Old Jul 2, 2011 | 09:11 AM
zx250's Avatar
zx250
I'm not sure about that, I used the drill/tap for mine and I know it's grounded. How far did you put the probe in the exhaust stream? You didn't bottom it out? I don't really know what else to tell you. Is you gauge and probe matched to work together?
Old Jul 2, 2011 | 09:39 AM
Crewcab Turbo
Isspro said it was the correct probe butt mabe not? I put the probe half way in, so it is in the middle of the air flow. It's a k type sensor. The Gage has a number it's r-606-25
Old Jul 2, 2011 | 09:50 AM
zx250's Avatar
zx250
Ok, well, something is wrong for sure. Either a bad probe, bad gauge or it could be in the wiring.
Old Jul 6, 2011 | 12:29 AM
VegasFordSD's Avatar
VegasFordSD
Originally Posted by Crewcab Turbo
I thought the temp especially at idol was low! I got the truck and it had the Isspro 3" Gage and wire under hood, someone removed and discarded sensor when installing 4" exhaust. Was post turbo. I bought another sensor and installed it pre turbo 2" after the exhaust manifold in the up pipe as instructed. Now that u mention it I just looked at the back of the Gage and the PO put the red wire on - not the + so the wires are backwards I assume! I'm in the company van now so il change it when I get back to my truck. I'm not sure if it will make a difference or not! Anyone have a used or cheap 2" pyro Gage for sale? I need a smaller Gage to fit in my Gage pod anyway! Hope the wire change will help for now!
Pat's old gauge is yours if you want it, just cover the shipping. I don't have a picture of it yet. I believe it is autometer with a silver bezel and white face. I will get a pic when I get a chance.
Old Jul 6, 2011 | 12:37 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Nice offer. I'd rep you if I could.
I try to share my stuff around with the FTE folk too.
Old Jul 6, 2011 | 01:05 AM
  #28
zx250's Avatar
zx250
Nice! Reps sent!
Old Jul 6, 2011 | 01:12 AM
  #29
slim613's Avatar
slim613
over time and reading amd lisening to a lot of people talk the best way has been the drill and tap method, well i hope u get all ur kinks worked out so u can enjoy ur dp tuner insted or worring,
i still gotta get my gauges :-/ al tho i did find the isspro kit for $358
Old Jul 6, 2011 | 01:15 AM
  #30
A/Ox4's Avatar
A/Ox4
9 ECHO 1
And you didnt tell me this $500 ago why?
