Hood Alignment Trick Worked!
Old Jun 29, 2011 | 11:39 AM
andgott's Avatar
andgott
One of the things that bothered me most on my truck was the hood- When it was closed, it was WAY off on the back along the cowl, as you can see in this pic-
I played with it a lot, but the hinges were already all the way down... My hinges are a little worn out, and I figured I'd either just have to live with it, or replace the hinges. I greased them up, as someone suggested, and that did help a little, but not that much.
I did a little research, and found several places, including this forum, where people recommended shimming the front bolt on the hinge with a couple of washers. I couldn't figure out HOW in the world it would work, if it did, but I decided to give it a shot. And- It worked-
No, it's not perfect- But it's a lot better than it was, and good enough for me! It no longer really stands out like it did before, closes much better, and rattles less. The hinges are a bit weak, but it looks like I'll be able to go a while longer now before I have to replace them!
A great trick- Hopefully it'll help someone else, too... My wife even said it doesn't look like it was in an accident any more
-Andrew
Old Jun 29, 2011 | 12:23 PM
jazzmaffy's Avatar
jazzmaffy
Wow big difference. Good deal
Old Jun 29, 2011 | 12:31 PM
ihateminimumwage's Avatar
ihateminimumwage
Nice! That always drove me crazy on my 63, good to know what to do when I pick up another slick...
Old Jun 29, 2011 | 11:37 PM
davewave649's Avatar
davewave649
wow looks good gotta do that on mine. wanna post pics of the shimming?
Old Jun 30, 2011 | 10:14 AM
andgott's Avatar
andgott
There isn't all that much to take photos of- But here it is-
The shim is under the front bolt- I used a couple of washers... The blue is masking tape- I taped 'em together so I could slip them in there and get the bolt in. Worked well!
-Andrew
Old Jun 30, 2011 | 04:25 PM
shortwide's Avatar
shortwide
cool....gotta love a simple fix like that
Old Jun 30, 2011 | 07:31 PM
CropDusterMan's Avatar
CropDusterMan
There is also another trick...these Ford hood hinges lack vertical adjustment, so by grinding a bit off of the
bottom of the hinge bracket, where it meets the cowl, you can gain the vertical adjustment you need.
Old Jun 30, 2011 | 08:08 PM
Marty in PA's Avatar
Marty in PA
Simple fix AND the wife likes it. Doesn't get any better than that.
Old Jun 30, 2011 | 08:16 PM
andgott's Avatar
andgott
That was going to be next- If this didn't work... I figured I'd try the easiest first, then move on to the grinder...
Old Jun 30, 2011 | 08:53 PM
99hosss's Avatar
99hosss
Thank yall for the tips. I just came in from this same senario ,the hood in the same crappy position. Will shim tomorrow Thank ya'll
Old Jul 1, 2011 | 02:15 PM
Customcab's Avatar
Customcab
Nice tech article in the making; thanks for the trick. looks great. Love the wreck comment. lol
Old Jul 2, 2011 | 12:12 AM
99hosss's Avatar
99hosss
Couldn't believe it, put 2 nuts under the front hingeplates, hood closed perfect, I mean factory perfect, still can't believe it
kr98664
'80-'86 HOWTO's
Apr 23, 2026 10:35 AM
abe
Feb 25, 2016 08:00 AM
tyrantsparky
Dec 22, 2013 10:22 PM
andgott
19
Sep 10, 2013 11:04 AM
andgott
24
Nov 15, 2012 06:33 PM
