Dual Tank Switch
Old Jun 29, 2011 | 07:43 AM
blloyd's Avatar
blloyd
Dual Tank Switch
My 87 F-150 has dual tanks with the black plastic switch, but I cannot tell which is the front and rear tank to know where to fuel up.
Can someone help me ?
Old Jun 29, 2011 | 08:02 AM
subford's Avatar
subford
The fuel door that is closest to the front of the truck goes to the front tank and the fuel door for the rear tank is closest to the rear.
Old Jun 29, 2011 | 08:07 AM
blloyd's Avatar
blloyd
Thanks Subford, but I was actually talking about the toggle switch on the dash to switch tanks.
The letters have gotten worn off !
Old Jun 29, 2011 | 08:19 AM
subford's Avatar
subford
The switch could be turned or changed but with a test light the Red wire is hot when the front tank is selected and the Brown wire with a white stripe is hot when the rear tank is selected.
The 1987 and the 1988 are wired the same:
Old Jun 29, 2011 | 08:21 AM
blloyd's Avatar
blloyd
Thanks, I will give that a try !!!
Old Jun 29, 2011 | 08:28 AM
subford's Avatar
subford
Note that the wires are hot with the engine running or cranking.
If you just turn on the key the the wires are only hot for one second.
Old Jun 30, 2011 | 12:12 PM
Buzzsaw's Avatar
Buzzsaw
Like someone said above the switch could have gotten turned around but my '94 F150 is Top is for Front and Bottom is for Rear. That's probably the standard way they would be installed.
Old Jun 30, 2011 | 12:17 PM
Jaime74656's Avatar
Jaime74656
its standard to have the switch be installed so the front tank is on top and rear tank is on bottom (switch possition) so your switch should be front top pushed in, or rear is bottom pushed in, unless you got this truck from someone else and they fliped the switch around...
Old Jun 30, 2011 | 12:22 PM
subford's Avatar
subford
His stile switch is a toggle switch and not the rocker switch.
It all depends on where his is mounted too. If it is mounted under the dash then when the switch is pushed forward for the front tank and pulled back for the rear tank. We have an 85 that way.
Old Jun 30, 2011 | 12:39 PM
Jaime74656's Avatar
Jaime74656
ah its one of those types, ok my bad, never had one so i don't know. I thought we were talking about the rocker style switch...
Old Jun 30, 2011 | 05:21 PM
blloyd's Avatar
blloyd
Actually I used the toggle phrase incorrectly and it is the factory black switch !
Rocker style would be correct.
Top pushed in will be on front tank !
THANKS !!!!!
Old Jun 30, 2011 | 05:40 PM
subford's Avatar
subford
The old computer saying, garbage in, garbage out.
Old Jun 30, 2011 | 06:50 PM
Jaime74656's Avatar
Jaime74656
yep GIGO
'86 F150
Dec 9, 2012 09:02 PM
seahawk56
Nov 21, 2011 04:18 AM
chucky0094
Sep 8, 2008 12:29 PM
D. DeBoer
Jan 9, 2005 05:54 PM
buzzard
May 4, 2001 01:36 PM
