2003 6.0L Engine Repairs and Upgrades - Input Please!
#46
so I put a sinister full egr deleate changed the up pipe and everything well now I lost a little of the 03 turbo whistle
I also thought maybe I have an exhaust leak in my uppipe or something and I cant feel it and only does it under boost IDK
but I get good fuel milage or average at 14 mpg and up per tank
And I do like that it looks stock
so I am thinking about doing the same as you
so is the intake end just have a freeze plug to or is it welded plate
also FWIW my 03 throws no codes from the egr deleate I checked with SGII and Innova code reader the Innova picks up on the codes better and nothing egr relaited
Im currios what your 03 will do as far as codes hope its like mine
03s RULE
03s RULE
#47
03s RULE
03s RULE
On the intake side of the cooler, I am going to cut a flat plate of thin stainless steel (like 24 gauge) and sandwich it in between the cooler and intake with one of the original gaskets on each side of it. Probably will reuse the original gasket on the EGR cooler side rather than buy two new ones.
#48
#49
#50
#51
#52
mine was the sinister egr deleate with just the one peice up pipe to change that eliminated exhaust to the egr cooler
Im thinking of going the same route you are though
stock and welded egr cooler ends heck its how I should have done it from the beginning changing that up pipe sucked I guess it wasnt that bad it would have been faster just blocking the cooler
#53
#54
But the egr cooler is out so I just need to find a good welder now
Im going to let the kit ride for a min untill I get it welded
#55
#56
#57
I used a press, but it had a good amount of resistance going in. If you think about it, seeing upwards of 50-60 PSI backpressure (max) on a 1 3/8" diameter soft plug (1.5 square inches area) means it would be seeing less than about 75 pounds of force. It took way more than that to push it into place.
#58
Thats what I was thinking and It couldnt go far all bolted back together
If the friction fit is good enought to seal it why not both ends and no welding IDK
#59
Soft plugs aren't stainless steel, and so they could corrode out over time and eventually leak. I'm not worried about that. The stainless plate I have on the other end won't leak, so worst case is the cooler lets go and further down the line the soft plug starts weeping and I see white exhaust and know to replace the soft plug. I'm more concerned about coolant definitely not making it into the intake, which is why the plate on that end will be stainless.
#60
Im with ya keeping coolant out of the intake is the main goal
can the plugs be found in stainless
