Newbee
Old Jul 17, 2011 | 05:09 PM
  #46
Splatts's Avatar
Splatts
SCT Live Wire
It doesn't show a lot of info about it.
Old Jul 17, 2011 | 05:39 PM
  #47
427 fordman's Avatar
427 fordman
For that price, you can get a custom chip from one I mentioned and a pyro. I don't know anything about that.
Old Jul 17, 2011 | 06:28 PM
  #48
Splatts's Avatar
Splatts
I don't think u can shift on the fly with it. So I found an 8 stage chip that will do pretty much the same thing and shift on the fly. The programmer allows 3 custom programs but the total price is $700. The 8 stage chip with shift on the fly is about $500
Old Sep 22, 2011 | 09:20 AM
  #49
Splatts's Avatar
Splatts
My truck feels real sluggish and it seems that my turbo isn't kicking in until 2100 rpms? Just put in a riff raff intakeand I couldnt tell any difference. Any ideas why this rig would be sluggish. Put the riff raff in my buddies truck and he can tell a big difference. Is it possible that my injectors need to be changed or any ideas what would cause this beast to be sluggish. Don't feel the power band until 2k rpms????
Old Sep 22, 2011 | 09:49 AM
  #50
Fullcrew7.3's Avatar
Fullcrew7.3
Low fuel rail pressure perhaps. There's a schraeder valve on the fuel pressure regulator that's on the driver's side of the fuel bowl. Use a tire guage to check the pressure at idle. it should be between 40-50lbs. Do a search for FPR shim and that will bring your pressure up to roughly 65-70 lbs. If your fuel pressure is below 30 psi, you should ge a new fuel pump. Also, between the FPR (fuel pressure regulator) and the fuel bowl there's a little screen that gets plugged up real bad and needs to be cleaned every now and then. You have to remove the FPR to get at it. THat should help with throttle response and fuel mileage a bit too.
Old Sep 22, 2011 | 09:52 AM
  #51
Fullcrew7.3
As for the engine RPM at speed, mine was 2500 @ 65ish with 4.10's and 2100@ 65ish with 3.55's. That's with the ZF5. I'm back to 4.10's now after the 4x4 conversion and 37" tires. I do miss the longer gears, but she pulls like a locomotive now.
Old Sep 22, 2011 | 09:55 AM
  #52
Fullcrew7.3
As for the injectors, they could be getting worn. Give Jim at Rosewood diesel (his link is at the top of the page) a call or email. He'll set you up withe some rebuilds or stage 1's for a real good price. And for the programmer, Darin hit it on the head with the custom chips he mentioned. Great price, great service and great products.
Old Sep 22, 2011 | 12:46 PM
  #53
Splatts's Avatar
Splatts
I was told that it could possibly be that my cat is clogged. I am goin to get rid of it eventually anyway so I am goin to delete the cat first. Can u send me a pic of exactly where this Fpr thing is at. That would be a big help. Thanks for all the info.
Old Sep 22, 2011 | 01:13 PM
  #54
Talyn's Avatar
Talyn
Midnight Mods: 7.3 PSD Fuel Mod
here you go.
Old Sep 22, 2011 | 01:16 PM
  #55
Fullcrew7.3
Talyn got to it first. Thanks man.
Old Sep 22, 2011 | 01:56 PM
  #56
Splatts's Avatar
Splatts
Sweet !! Thanks fellas!!!
Old Sep 22, 2011 | 02:00 PM
  #57
Talyn's Avatar
Talyn
I'm glad I put that article up on my site finally.
Old Sep 22, 2011 | 05:58 PM
  #58
Splatts's Avatar
Splatts
Where exactly is that filter that needs
To be cleaned
Old Sep 22, 2011 | 07:10 PM
  #59
Talyn's Avatar
Talyn
I'll find a picture and throw it up. Give me a few.
  #60
Fullcrew7.3
It's a little wire mesh screen about 5/8" diameter. It's actually part of the FPR assembly. When you remove the FPR it will be in the piece that comes out of the fuel bowl. There's supposed to be a check ball in there as well, but mine hasn't had one since I got it. PO must have dropped it.
