Scan Gauge II - Boost issue, EOT temp?
Old Jun 30, 2011 | 06:29 AM
jdadamsjr's Avatar
jdadamsjr
Originally Posted by shawnna
*sigh*
Honestly guys, all of these posts seem so foreign to me.
I'm waiting for my new ScangaugeII to be delivered and it's scaring me thinking about programming it, much less understanding what it is I'm seeing once I do.
Isn't there a cliff notes version or "ScangaugeII for Dummies" guide or something?
And it IS foreign to most of us, until we know how to do it...
Don't be skeered
Did you ride your bicycle full speed when you first got it ?
programming it is as easy as following some prompts and cycling thru some numbers...
pick an extra gauge that is easy to type and works for all...
it will be slow at first but once u get the trick of it, it goes fast...
And the best thing about it, the SG2 is a read only device, not like you can mess up your truck or anything... either the code you type in will work or it won't.... if it doesn't work, just type over it and try again !
Only thing that will hurt the truck or the gauge is if you get frustrated with it and throw the sg2 against the dash
Old Jun 30, 2011 | 06:34 AM
River's Avatar
River
Originally Posted by amdriven2liv
Would be interested on your findings. Do you have Fan speed set up? would like to see what you get with that.
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
Where did you get a SGII with a preprogrammed "boost"?
Mine wasn't in there when I got mine. I had first entered boost from the Xgauges page, and had the very same situation as you, negative numbers after 20 or so. Matter of fact, most did. James from Scangauge resolved our issues on this. Just hopw they update the website soon.
You will do fine.
Sean
It came with a choice of MAP or BST when you first set it up. It said in the manual that if I had a diesel, to choose BST.
Old Jun 30, 2011 | 06:36 AM
River's Avatar
River
*sigh*
The fine folks here at the FTE forum are always willing to help someone out. Once you read the manual, you'll do just fine. And like the guy above said, you can't damage anything!
Old Jun 30, 2011 | 06:37 AM
npccpartsman's Avatar
npccpartsman
Boost is the most useful and is a modified MAP signal. MAP, EBP and Baro are very useful for correlation diagnostics but EBP won't work on an 03.
mdelfunt
Aug 7, 2016 10:13 PM
Mcrafty1
Jul 20, 2015 05:41 AM
99ExpyProblems
Oct 9, 2013 01:47 PM
tdh136
May 21, 2012 10:01 AM
hndacr
Jun 2, 2010 08:31 AM
