Intermittent Starting Problem
Old Jun 28, 2011 | 11:32 AM
Steeler Fan 4 Life's Avatar
Steeler Fan 4 Life
I recently replaced the upper bearings in the steering column in my 1996 F150 4x4(302, Auto, tilt, cruise, airbag). Everything went fine for a week or two and now, sometimes when I try to start it.......NOTHING! Turn the key back off and try again......NOTHING! Try it again it will start. Sometimes it will start first try, sometimes 2-3 tries, sometimes 1 try, sometimes 3-4 tries......you get the picture. I am wondering if the ignition switch is not making contact all the time or what. Any suggestions??? Thanks
Old Jun 29, 2011 | 07:00 AM
Lazy K's Avatar
Lazy K
Could be a few things but I think I would try adjusting the ign switch. It is bolted to the side if the steering column under the dash with two bolts. Loosen the bolts and slide it down the column a little.
Country Traveler
Mar 14, 2014 08:02 PM
bulldoggish
Escape & Escape Hybrid
Jan 8, 2014 07:19 PM
OIF_VET1775
Oct 3, 2012 10:19 AM
BlackFX4Screw
2004 - 2008 F150
Dec 21, 2008 08:52 PM
jwith68
Aug 24, 2006 08:25 AM
