We just recently purchased a 2001 eddie bauer expedition 4x4 with the big v8. can anyone tell me where to find the factory keyless entry code? Also the blinker on the side mirrors are not working..the binker is not in the glass but on the side of the mirror..does that make since? Any help would be great!!
If you dont know the code, the Ford dealer can get it out of the computer. It will be 5 digitd long. Then you can program your own 5 digit number you can remember.
The code is on a label on the computer, under the dash, drivers left side. It might be above or behind the left side kick panel above the foot brake. It's in that area and you can't miss it.
Thanks for the info! Got them fixed! Now on to the cruse control...any ideas there? Checked the fuse its good!..
Hard to tell, you haven't said what's wrong with it. Assuming it doesn't work at all, the previous owner may have disconnected it rather than have the recall work done it to prevent engine compartment fires. Actually when they were first recalled there was a shortage of repair parts so the dealers were disconnecting them. Could be the person never went back after that to have the work done.
The good news is that if it is unfinished recall work, it will still be covered.
Auto Recall Date: 09/07/2005
Vehicle Component: VEHICLE SPEED CONTROL
Estimated Vehicles Affected: 4500000
2001 FORD EXPEDITION Defect Summary:
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES EQUIPPED WITH SPEED CONTROL, THE SPEED CONTROL DEACTIVATION SWITCH MAY OVERHEAT, SMOKE, OR BURN.
Defect Consequence:
A FIRE AT THE SWITCH COULD OCCUR.
Remedy:
BY LETTER DATED SEPTEMBER 12, 2005, OWNERS WERE INSTRUCTED TO RETURN THEIR VEHICLES TO THEIR DEALERS TO HAVE THE SPEED CONTROL DEACTIVATION SWITCH DISCONNECTED. OWNERS WHO HAVE HAD THEIR SPEED CONTROL DEACTIVATED ARE BEING NOTIFIED THAT PARTS WILL BE AVAILABLE AND ADVISED TO MAKE AN APPOINTMENT TO RECONNECT THE SPEED CONTROL BEGINNING IN FEBRUARY 2006. OWNERS WHO DID NOT HAVE THEIR SPEED CONTROL DEACTIVATED ARE BEING NOTIFIED TO HAVE THEIR SYSTEM REMEDIED BEGINNING IN FEBRUARY 2006. OWNERS ARE URGED TO AVAIL THEMSELVES OF THE FREE DISCONNECT SERVICE AS SOON AS POSSIBLE BECAUSE OF THE SIGNIFICANT RISK OF FIRE. OWNERS MAY CONTACT FORD AT 1-800-392-3673. (NOTE: ALSO SEE RECALLS 05V017 AND 06V286)
Notes: FORD MOTOR COMPANY, 05S28
