I mock things up with poster board and duct tape. I transfer that to the metal and then tack things together under the truck on my back. Then I take it to my table and weld it up. I NEVER do an overhead or verticle weld unless I have to. Not because I can't, but because I am more confident in my ability and more willing to gamble my life against my flat or horizontal weld. Aside from the safety factor it simply looks better. I don't want anyone to look under my junk and say "damn, that looks like ***" and my reply be "yeah I let a friend practice on my drop brackets and I was too lazy to unbolt them and weld it up properly.
At first I was glad to see you tackle an SAS but as it progressed and I noticed your repeated disregard for the suggestion of bolting it in rather than welding and now your **** poor fab job/off center axle placement I see that you are no different than the majority of hackjobs that have plagued FTE since its beginning.
If u extend the stock arms build the **** out of them.
1.5ddom is too small
This!
I can't remember the OD of the stock arms but somthing in the 2.25 -2.5" range with a .375 wall and a 1.25" heim would work great. Sleeve the whole thing, weld the DOM to the C itself but I'd bring more than that little Hobart 140
UPDATE: Well just got off the phone with JD... radius arms on order. After much thought and everyone's input, I just didn't feel like messing around with the welding cast and always worrying about them leaving me stranded. $800 burnt up, but the piece of mine should be worth it.
After review I do have the 6" super-flex springs. I have the tall James duff towers as well. But after looking around some more I plan on moving them all the way forward (another 1") to help with the tracbar and I will try to move them up as much as I can.
Only questions now:
1. 4* C bushings or keep the ones I have?
2. Also what is the correct way to measure for shocks?
3. Also caster should be around 4-5*? I'm assuming the Duff arms will correct this for me.
Thanks for the input so far, be it positive, or negative!! And Alpha it's a hobart 220 lol
