perfect! i might have to do that upgrade then, something cheap and easy to get me a few more ponies, looks like the efi manifolds are set up to be able to run true duals also?
If you want to drive this truck when the temp is below 40F, you'll need to cobble up some sort of intake manifold heat. Many of the folks who install the fuellie manifolds to their carbed truck have made a plate that bolts to the bottom of the intake: see post #10 here;
Another option is to find a log style manifild from an F450 of 70's vintage and use it. It has a huge exhaust exit, and with good exhaust on it it'll work nearly as well. It'll also retain the carb heating function that you'll need in the country you live in. Picture here; http://fordsix.com/forum/viewtopic.p...ght=hd+exhaust
