Bypassing PATS
Old Jun 27, 2011 | 09:31 PM
hsb's Avatar
hsb
Bypassing PATS
I have an 04 Eddie Bauer Explorer, approx. 140k miles. Seems a component on the PATS has failed, I know its not the key. Is there a way of bypassing it or am I left with taking it to the dealer??
Old Jun 28, 2011 | 06:50 AM
shorod's Avatar
shorod
Welcome to the forum!
I don't recall having ever read of the PATS module failing. Care to share a bit more details on your symptoms so we might be able to provide better troubleshooting support?
The PATS module will disable the vehicle if you remove it, and the PCM needs to see the correct PATS module coded to your vehicle in order to allow a start condition, there's no way to completely bypass it or to install another one (without reprogramming it to the vehicle with a dealer scan tool).
But I doubt the PATS module is the issue. Maybe the antenna around the ignition key cylinder or associated wiring is the problem, but again, not understanding your symptoms, it's just a guess.
-Rod
Old Jun 28, 2011 | 07:01 AM
antony25's Avatar
antony25
This is a common problem on '04. Have dealer reprogram pcm per tsb 04-14-02
Old Jun 28, 2011 | 12:08 PM
hsb's Avatar
hsb
Thanks for the reply. Its at the dealership now. Hopefully it will be done today or tomorrow.
Old Jun 30, 2011 | 05:32 PM
hsb's Avatar
hsb
Well I get a call from the dealer today, two blown fuses in the security system, its fixed, not really sure why it blew the fuses, but good to go, $150 and an hour later Im back on the phone with them, same thing happened again. Apparently they just put a bandaid on the prob. instead of tracing the short that caused the fuses to blow in the first place. So now Im out of a vehicle again till who knows when.
Old Jul 4, 2011 | 09:21 PM
hsb's Avatar
hsb
Final update, apparently the shop I had do some tranny work a few months back rerouted the O2 sensor wires which resulted in one of the wires chaffing through.
Old Jul 4, 2011 | 10:56 PM
aquanaut20's Avatar
aquanaut20
What connection does the O2 circuit have with the PATS??
Old Jul 5, 2011 | 02:11 PM
hsb's Avatar
hsb
PATS and the sensors all go back to the same computer
97expy
Oct 27, 2020 12:14 PM
RDele
Aftermarket Products
Feb 5, 2018 04:34 PM
jas88
26
Jun 17, 2017 09:00 PM
Powersmoke_sd
Mar 10, 2017 12:01 AM
Phred P
1997 - 2003 F150
Sep 18, 2014 01:38 PM
