O2 sensor
Old Dec 4, 2002 | 09:27 PM
robnooy's Avatar
robnooy
O2 sensor
Have a 1989 F-150 with 302. Had dual exhaust installed. Cats removed and the O2 sensor replaced into the right side pipe. With the cat gone what will that do to the readings that the O2 is taking.Will it make performance worse or better. I get 11 or so miles per gallon. thanks.
gotta burn gas to make noise
Old Dec 4, 2002 | 09:35 PM
steve83's Avatar
steve83
O2 sensor
The HEGO was before the cats, so it sees the same thing, but it's only seeing the exhaust from one bank of the engine. It may make the computer THINK the engine is running lean, so it may MAKE it run rich, but that's a guess.
Performance will probably drop slightly.
Old Dec 4, 2002 | 10:37 PM
EPNCSU2006's Avatar
EPNCSU2006
O2 sensor
My guess is that the O2 sensor senses the percent oxygen in the exhaust, so theoretically, the percentage should be the same for each side, and if you put them together, only the volume of exhaust would change, while still sensing the same percentage of oxygen.
Old Dec 5, 2002 | 01:14 AM
mike_v2v98's Avatar
mike_v2v98
O2 sensor
i did the same on my 95 f150 302
put on dual exhaust with no cats and just left the o2 sensor on one side of the exhaust
my mpg dropped to about 8 or 9
took the truck back and had headers put on with an H pipe and put the o2 sensor in the middle of the h pipe
im back up to about 14 or 15 mpg and alot more throttle responce
not to mention a really cool sounding truck
lol
Old Dec 5, 2002 | 07:34 AM
EPNCSU2006's Avatar
EPNCSU2006
O2 sensor
Just a curiosity question, did you have an h-pipe before you put one in for the O2 sensor?
Old Dec 8, 2002 | 11:30 AM
robnooy's Avatar
robnooy
O2 sensor
what would happen if i had the two pipes join into one using a y-pipe and then place the O2 sensor after the y-pipe.
Old Dec 8, 2002 | 12:02 PM
steve83's Avatar
steve83
O2 sensor
That's really what the exhaust shop should have done to begin with. Either the Y-pipe you just described, an X-pipe system, or an H-pipe with the crossover no longer than twice the diameter of the 2 pipes.
Old Dec 8, 2002 | 01:11 PM
Racerguy's Avatar
Racerguy
O2 sensor
wrenchman2
Exhaust Systems
17
Nov 18, 2011 05:03 PM
braaper92
Mar 6, 2009 07:55 AM
96_fordF150
Jul 10, 2008 11:02 PM
tadssman
1983 - 2012 Ranger & B-Series
Jan 11, 2007 11:19 AM
SeannyBoy84
Exhaust Systems
Oct 17, 2005 04:17 AM
