302 Problems with 2150 carb
Old Jun 27, 2011 | 10:26 AM
jeddi03's Avatar
jeddi03
So I think i may have found the culprit to my problems. I could get my 302 to run well at idle, but had a miss/surge in the higher rpms. So after running a vacuum check while driving it appears that I have a intermittent lean spot.
I started looking at my carb. I think i have two problems. One is an easy fix and the other, well I definitely need help.
The easy fix is jetting. I think that my jetting is a little to lean. The stock in the carb is a 49 in my 2150 carb. When I install my Holly 4412 the jet is a 69 and I can eliminate all problems with that carb set up. I think if I can richen that circuit that it will perform better. Now on to my more difficult problem.
Upon further inspection, the venturi cluster on my 2150 has a huge crack running down one of the emulsion tubes. I am assuming that with this crack in the emulsion tube that the carb can't run like it is supposed to.
Does anyone have one they could sell me? I tried looking on ebay. I have called holley direct. they can sell me the complete carb, but not the individual piece. I called daytona carb. Same story.
I appreciate the help!!!
Old Jun 27, 2011 | 11:38 AM
Boba Fett's Avatar
Boba Fett
Glad to hear you found the problem..... I would check Craig's list too..... Last time I needed one, which is ten years ago now, I was able to get one through NAPA.... but maybe they just aren't supported anymore.....
Old Jun 27, 2011 | 03:58 PM
Beanscoot's Avatar
Beanscoot
Cracked idle emulsion tube
Ford calls this part a "booster venturi assembly".
I might have a spare, but first, can you post any markings on yours? Also, what is the main venturi size of your carburetor? This is found cast into the side of the carb body in a circle and will be 1.21 or 1.09 or similar.
Ford jets are not sized the same as Holley ones so don't assume yours are too small.
At idle the mixture screws can be adjusted enough to compensate for the faulty emulsion tube, but once the throttle is opened more, the cracked tube causes a poor mixture.
Where are you located?
Old Jun 27, 2011 | 06:15 PM
jeddi03's Avatar
jeddi03
One of the techs at our ford shop in san luis obispo has one at home that he is bringing tomorrow.
The number on the venturi is A DD5. The number on the carb body is 1.08.
Hopefully his works long enough for smog. After that, it's back to the 4412 for two years.
drewduncan15
Feb 1, 2020 06:24 PM
dgoodman
Jun 6, 2014 04:19 PM
reverendxlt
Dec 10, 2011 07:04 PM
Edgewood
May 13, 2010 09:09 AM
Diesel Digger
Apr 4, 2006 02:40 AM
