7.3 engine build
Old Aug 7, 2013 | 02:08 AM
  #76
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
He is about to be a Dad, Jason. He will be messing with the baby's butt for years!
Old Aug 7, 2013 | 02:25 PM
  #77
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
Thanks guys!
I was thinking with the money I have into the 38r and the bellowed up pipes I wasn't far off from going to another setup. Mostly for the rebuildable factor. I am also having turbo surge.
As much as I hate to say it, I think I may need to go with some different tunes as well. All my tunes are smokey and I can't really use my 100hp race cause my egt's get up way to fast. Jody tried changing a couple things but then I just get this is exactly how my tunes are set up for other people with my set up.
Old Aug 7, 2013 | 02:51 PM
  #78
snknby123's Avatar
snknby123
What's the deal with the coolant? Is it a bad cap or is it over pressurizing?
Old Aug 7, 2013 | 04:10 PM
  #79
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
Not quite sure. Not the cap I have tried a few and tested them all. Tried a couple thermostats and even no thermo stat. I have changed radiator and water pump. I have done compression tests as well as cylinder leak down. Everything passes. It will go weeks without out doing it and then will do it for a couple of days with no rhyme or reason and then quit.
Old Aug 7, 2013 | 08:51 PM
  #80
SkySkiJason's Avatar
SkySkiJason
Been there done that.
I was very happy with Gearhead tunes in the X (this engine w/AC's and S366). There is no comparison to my 'old' toons. Specifically no more smoke and EGT's are never an issue - EVER.
Old Aug 8, 2013 | 08:26 AM
  #81
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
That's good to know. I remember we talked about this before. I am definitely leaning towards gearhead, I have heard nothing but good things.
Old Aug 9, 2013 | 08:44 AM
  #82
snknby123's Avatar
snknby123
So no bubbles in the reservoir during the leak down tests? Hate to say this man but it sounds like a head gasket issue to me.
Old Aug 12, 2013 | 07:47 AM
  #83
SkySkiJason
Any indication of fuel in the coolant? Injector cup issue?
Did you inspect the coolant passages, specifically the cylinder walls? I wonder if this could be the problem?
What HG's did you use? How many miles on the engine now? What is max boost you've seen?
Is this enough ??????????'s
Old Aug 28, 2013 | 07:46 AM
  #84
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
There is no fuel in the coolant at all. I checked what I could for the coolant passages and did not see anything wrong that caught my attention. I am wondering if there is possibly a hairline crack in a cylinder wall but I assumed the would show on my leak down test. I am using cometic head gaskets .060" if I remember correctly. Really regret not having the pistons shaved and running stock HG's. I have just under 10k on it now. My boost gauge stops at 35 but I can bury the needle.
Old Aug 28, 2013 | 08:20 AM
  #85
SkySkiJason
Bummer. Could be HG's... The CP's at high RPM and boost are MUCH higher than leak down test and you could be lifting a head. I wish I knew how to determine that for ya......
I don't remember - are you running studs or head bolts?
Old Aug 29, 2013 | 12:50 PM
  #86
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
I am running arp head studs. If head was lifting wouldn't there be signs of coolant in the oil as well? This has had me scratching my head for awhile now
Old Aug 29, 2013 | 05:22 PM
  #87
SkySkiJason
Bump!!!
I guess its possible it could be an injector cup issue and it only leaks at high pressure?
Old Aug 29, 2013 | 05:23 PM
  #88
SkySkiJason
Bump!!!
Old Sep 26, 2013 | 02:30 AM
  #89
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
I guess that would be possible. Now that I have some miles on it I just need to pull the valve covers and take a look around.
Old Sep 26, 2013 | 07:23 AM
  #90
joeyd61's Avatar
joeyd61
This could be the issue, I went through 3 sets of COMETIC head gaskets on my build. On mine, the gaskets couldn't stand high boost numbers. Finally gave up and after a LOT of inspecting, went back to stock head gaskets,the clearances are real close but no more issues..
