Ignition Loose
Old Mar 27, 2003 | 08:07 PM
AdamTN's Avatar
AdamTN
Question Ignition Loose
The igniton in my explorer has got to the point that you can turn on the accessories without having the key in it and it can just move around a whole bunch. It's a 93 explorer, I'm not sure what has to be replaced, just the lock cylinder, I'm not sure? Has anyone done this before? Should I just take it to the dealership, and if so how much do you think run? Thanks!
Old Mar 28, 2003 | 12:26 PM
Dialtone's Avatar
Dialtone
Ignition Loose
It is an easy DIY job and not too expensive either. Get a replacement lock cylinder at Autozone or such for around $20. Take it to a locksmith and have it rekeyed to match your original keys for around $25. R&R requires you to remove the plastic lower/upper steering columh housings and steering wheel. Once that is done, take a thin, long blade screwdriver and insert under right side of tilt mechanism going up at about a 45 degree angle and depress the cylinder lock pin (key in and truned to accessory position)- then pull cylinder straight out.
Ford wanted to sell me a complete set of locks for big bucks and that did not include labor.
The release pin is fairly obvious if you get the new cylinder and look it over before you try the R&R. If you have SRS airbag, the process is more involved and somewhat more tricky.
Dialtone
Toored
Nov 2, 2012 08:01 AM
aortizexcursion
Apr 13, 2009 02:36 PM
djbeasties
Dec 31, 2004 12:50 PM
Detroit_Player
Apr 13, 2003 06:42 AM
N700MS
Feb 25, 2002 08:45 PM
