95 Power Stroke , PO605 Code
Old Jun 25, 2011 | 08:49 PM
kirksf1's Avatar
kirksf1
This truck starts and runs good when cold. After the engine fully warms up when you turn it off it will crank fine but will not fire off. If you let the truck cool down for a few hours it will start fine. There was a intermittent cam sensor fault code and this ROM code. I have replaced the cam sensor with no results.I used a heat gun on the ECM to try to duplicate the problem with no results. Has anybody had this code cause this problem? Where is a good place to purchase a computer? Any input would be very much appreciated.
Old Jun 25, 2011 | 10:50 PM
Josh88Ford's Avatar
Josh88Ford
you'll be better off posting this in the 94.5-97 obs diesel forum. With the 2nd gen motors, cam sensors are very picky and need to get the right one. www.riffraffdiesel.com sells the original black cps which is as good as they get. Any other brand from the parts store are typically junk.
Old Jun 26, 2011 | 03:56 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...start-hot.html Click on this link and read it.
Old Jun 26, 2011 | 06:36 AM
subford's Avatar
subford
With a PO605 it does sound like a bad computer (Rom Error).
Just take it out and get one from an auto parts store.
u-nameit
Jan 24, 2011 11:02 AM
cjben
19
Aug 16, 2008 12:32 PM
l965mustang
1997 - 2003 F150
13
Mar 5, 2005 11:03 AM
KM0L2002
Nov 30, 2003 08:12 PM
reachart
Sep 23, 2003 07:05 PM
