2000 Explorer engine codes
Old Jun 25, 2011 | 05:23 PM
Okidragon's Avatar
Okidragon
My 2000 Explorer (4.0 SOHC) has P0171 and P0175 codes. Several possibilities given from Auto Zone. It was running perfectly until 2 days ago. Sputters like a misfire, loss of power when accelerating, but will maintain highway speeds. Under the hood the "odd" sounds are coming from the passenger side (bank 2 I believe?) and seem to be very directional as to where they're originating. My thoughts are a single injector gone bad since it was abrupt and since it will even out for a bit almost completely but then sputters again. Would a sensor or vacuum leak suddenly do this? Still thinking injector... Thanks everyone!
Old Jun 27, 2011 | 05:54 PM
aquanaut20's Avatar
aquanaut20
P0171 bank 1 running lean
P0175 bank 2 running rich.
This is a case of connecting a scanner (not a code reader) and checking O2 switching and LTFT...
Reset the CEL and see if the codes return.... Post results... Philip
809taino
Feb 5, 2013 07:52 AM
loony2000
1997 - 2003 F150
Sep 9, 2007 09:36 PM
fordguy1
Mar 22, 2007 07:15 AM
jleberer
Feb 2, 2007 02:49 PM
shorthair
May 3, 2005 09:30 AM
