help please
Old Jun 25, 2011 | 03:42 PM
colind's Avatar
colind
help please
hey got a? i have an 03 ranger fx4. iv done the inner,outer tie rods,upper and lower balljoints,shocks,hub,all 4 stableizer bushings,cranked up torshins.still have a clunk when going over speed bumps.its coming from the passengers side. be thankful for some ifo!!!
Old Jun 25, 2011 | 08:44 PM
Old93junk's Avatar
Old93junk
Try replacing the slide pins that hold the brake calipers together, when they get sloppy, the calipers clunk going over bumps.
Old Jun 26, 2011 | 08:33 AM
Rackster's Avatar
Rackster
It goes 'clunk'
You may want to check your motor mount on that side. I had an '80 Buick Skyhawk that went through them routinely. I would hear a clunk (or a crash when the airfilter cover hit the hood). Pop the hood and peak through the gap when brakes are on and engine/tranny in gear. Be safe!!! See if the motor rises excessively and if you hear the clunk once it comes to rest (assuming that's the issue).
Thanks for the tip, 93. I hear a rattle every once in a while when driving with the window down - this might just apply to my situation.
Kevin
Old Jun 30, 2011 | 08:56 AM
speace91's Avatar
speace91
the rattle with your window down more than likely is the window bouncing around in the door.
Bruker
Feb 24, 2009 05:12 AM
joeskeeter
Feb 21, 2008 10:23 AM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
00sc4x4
1997 - 2003 F150
Nov 3, 2003 06:56 PM
stoab
Sep 10, 2002 01:13 AM
