Injectors?
Old Jun 25, 2011 | 12:20 PM
Fire85's Avatar
Fire85
Injectors?
I have an 06 F-350 CC LB 6.0L w/ 103k miles. Here's the problem... When I intitially start the truck either in the a.m. or after it sits for a few hours it's angry. It compares to when it's cold out and you forget to plug it in. Along with that there's just alittle bit of white-"ish" smoke from the tail pipe. After I let the truck sit about 10 minutes idling, it runs fine w/ no smoke. This is doing it even when it 97*F outside. Would like to hear some thoughts so I know where to proceed.
Thanks in advance,
Ben
Old Jun 25, 2011 | 12:41 PM
BLADE35's Avatar
BLADE35
check FICM voltage
https://www.ford-trucks.com/forums/8...procedure.html
click here^^^^^^^^^^^^^^^
Old Jun 25, 2011 | 01:12 PM
gearloose1's Avatar
gearloose1
Try adding Ford cetane boost and see what difference it makes.
Old Jun 25, 2011 | 01:24 PM
Fire85's Avatar
Fire85
I will check the FICM tomorrow when I get a chance. Thanks for the info. I will let you know what I find out.
Ben
Old Jun 25, 2011 | 02:01 PM
BLADE35's Avatar
BLADE35
I use a scan gauge II to watch
FICM volts
and a bunch of other stuff
well worth it if you need a gauge and are on a buget
no fuel press or egt gotta start from scrtch on these 2
Old Jun 25, 2011 | 06:07 PM
npccpartsman's Avatar
npccpartsman
How many miles on your oil change? Sounds like injector stiction to me, but DO check your FICM voltage also.
Old Jun 25, 2011 | 09:12 PM
smokersteve's Avatar
smokersteve
fire85 are you loosing coolant? or any pushing out of the cap?
I agree on the question, how long are you on the oil? what kind? and how long do you go on the oil changes?
Old Jun 25, 2011 | 10:36 PM
Fire85's Avatar
Fire85
No loss of coolant and nothing coming out of the cap. As for my oil change it's at 3k-5k miles. I'm getting close to the 5k since my last oil change. I have the stuff do change it at home and plan on doing this tomorrow. Also, I'm using Rotella T and ,this is gonna sound bad, but I think it's 15w40. I will check tomorrow when I get home to see what I have.
Ben
Old Jun 25, 2011 | 10:53 PM
Roasted7's Avatar
Roasted7
A scangauge is very well worth the money. I found all kinds of issues that I otherwise had no idea was going on. An excellent tool to keep tabs on the health of you 6.0. If your not losing any coolant and remedies such as rev-x and synthetic oil make no difference, then I'd say your FICM is suspect. It's an easy do-it-yourself fix.
Old Jun 25, 2011 | 11:00 PM
smokersteve
15w-40 is not bad at all. your oil intervals are very good no worries!
I will also be checking my ficm in the next week or 2.
SCRebel
1997 - 2003 F150
15
Jul 21, 2013 08:28 PM
08F1Tizzy
2004 - 2008 F150
Mar 1, 2013 09:04 AM
dredgeman
Apr 16, 2008 02:31 PM
fencer
Modular V10 (6.8l)
Dec 8, 2007 02:06 PM
300Runner
Sep 16, 2002 07:27 AM
