'84 Dip Stick Frustrations
Old Sep 30, 2012 | 09:33 AM
  #31
AbandonedBronco's Avatar
AbandonedBronco
Interesting stuff.
I also went out and looked at the '84 engine and it doesn't even have a spot for the rear dipstick. There isn't even a boss sticking out for it.
Fortunately, I do have an extra oil pan in the garage that has a dipstick going into the pan itself. Next time I'm up for it, I can just swap the pan. I don't think I have any other options!
Old Sep 30, 2012 | 03:29 PM
  #32
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by AbandonedBronco
Interesting stuff.
No, it doesn't look like you do in this situation. Someone replaced the engine with an older block it looks like.
Old May 19, 2017 | 03:46 PM
  #33
ooCHICOoo's Avatar
ooCHICOoo
Oil pan frustrated
Same problem with my oil pan have 4.9 engine 300cc 84 year my engine have the tube stick next to pump gasoline
problem always to check engine oil dipstick
never give me the correct information
E2TZ-6750-D .. 300 I-6 Engine Oil Dipstick-Pan mount type / Marked: E0TE-EA or EB; E2TE-GA.
Applications: 1980/82 F100/350 & Bronco.
E2TZ-6750-F .. 300 I-6 Engine Oil Dipstick-Block mount type / Marked: E2TE-JA / Obsolete
Applications: 1983/85 F100/350 & Bronco / 1986 F150/350 & Bronco before 11/1/1985.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
Old May 20, 2017 | 02:51 AM
  #34
ctubutis's Avatar
ctubutis
Huh? Proper sentence structure & grammar go a LONG way at making your post readable & answerable.
And so you're waking up a 5 yo thread and trying to ask WHAT???
Old May 20, 2017 | 03:29 PM
  #35
ooCHICOoo's Avatar
ooCHICOoo
I don't fine my oil dipstick for my engine that's the problem
Old May 21, 2017 | 01:21 AM
  #36
ctubutis's Avatar
ctubutis
The source of that dipstick is one of two places:
1) The side of the oil pan
2) A hole in the block near the distributor.
Which one depends on which application (truck or sedan) the engine was assembled for, people swap in car engines all the time....
Old May 22, 2017 | 02:46 PM
  #37
1986F150six's Avatar
1986F150six
Trying to understand so we can better help you!
00CHICOoo, do you mean that what is shown on the dipstick is not accurate? In other words, if you have just changed the oil, used a new oil filter and poured in 6 quarts of oil, does the dip stick not show "full"? If that is what you are saying, open this link and see what was suggested: https://www.ford-trucks.com/forums/1...e-help-me.html
Old May 22, 2017 | 10:03 PM
  #38
ooCHICOoo's Avatar
ooCHICOoo
Oil pan
Originally Posted by Rogue_Wulff
Dipstick goes into the block in front of the dist, yet it looks as if the sump is well behind the oil filter. I don't see how the stick could reach the sump.......
My pan has the sump in the same basic location, and the dipstick goes thru the side of the pan, behind the filter. In fact, it's slightly loose where it goes thru the pan, so it spends 99.9% of the time with the tube resting on the filter. I always move it away as I change the filter, but it's right back on it within seconds of starting the engine.
Do you know we're is the part number of the oil pan , it's on front or back sade
Old Apr 8, 2018 | 02:24 PM
  #39
Motormom1983's Avatar
Motormom1983
Oil pans
we are putting a f250 4wd 1976 300 4.9 inline six into a 1983 f150 2wd. Do we have to swap the oil pans? Will the 1976 fit like it is or do we have to put the 83 oil pan on the 76?
Old Apr 8, 2018 | 02:37 PM
  #40
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Did'ja happen to notice where ooCHICOoo is from? Probably not.
"About Me" profile says PR which I assume is Puerto Rico where English is the second language.
Old Apr 8, 2018 | 09:21 PM
  #41
ctubutis's Avatar
ctubutis
"About Me" profile says <acronym title="Page Ranking"><acronym title="Page Ranking">PR</acronym></acronym> which I assume is Puerto Rico where English is the second language.
Hmmm....
Did you happen to notice the date on which I made that post, Bill?
Probably not; but it was almost a year ago at this point.
Old Apr 8, 2018 | 09:33 PM
  #42
NumberDummy
Hmmm....
Yes, I noticed the date, but what the hell difference does that make?
The thing is, you did a 'NumberDummy' on the by being crabby because you didn't like the way he parsed sentences.
Spanish is his first langauge and I think he did pretty well, considering.
IMO: One crabby old SOB is enough, FTE doesn't need another.
Old Apr 9, 2018 | 10:04 AM
  #43
AbandonedBronco
I believe so. The '76 engine has a centrally located sump, whereas the '83 has a rear. It was moved to the rear to avoid the axle.
If you use the '76 oil pan, it'll hit the axle.
Fortunately, the '83 will fit onto it just fine.
Old Apr 9, 2018 | 05:05 PM
  #44
Motormom1983
Thank you. You are correct it will not fit. Now we have the same problem the other guy had. We have no way to check the oil because the dip stick in the 76 is in the front of the engine (shallow end of the pan). The dip stick in the 83 is in the back of the engine.
Old Apr 9, 2018 | 05:12 PM
  #45
AbandonedBronco
This was my issue. I eventually fixed it by getting an oil pan that has the dipstick in the pan itself. You can probably source the bracket and dipstick tube from a junk yard.
But, without this, there's no way to check the oil.
Ford Bronco Pickup 4.9/300 Oil Pan Ford Bronco Pickup 4.9/300 Oil Pan
Note that this oil pan does NOT come with the raised ridges around the bolt holes, so you would need to use an 89+ 1 piece silicone gasket, which is an upgrade anyway.
